Old 05-12-2004, 04:00 AM
clausiii's Avatar
clausiii clausiii is offline
Default Wave driver/ASIO driver
Please, I need some advise! Can someone explain, how to get them to work properly?
I can´t get them work with Wavelab (4.0.1b) at 24bit/48kHz. 44.1/16 works fine. The "Sound Mapper" of Microsoft works! I can´t get it!
btw the DigiWaveDriver ain´t able to record with WL it doesn´t appear in the WL prefs.
Should I set the DigiWaveDriver as system audio driver in the sounds and multimedia settings in XP?
btw (part 2) I tried the MMEhelper, it made the driver in WL visible, but it seems, this is not a "multiformat"-driver (for me for now).
as an appendix one more question: what´s the right workflow:
bouncing my 48/24 mix in ProTools @48/24 and mastering and conversion this file in WL?
bouncing my 48/24 mix in ProTools @44.1/16 and mastering this file in WL?
Thanks for your hopefully soon coming comments...!
PT 6.4
Digi001
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2019.5
Digidesign Command|8
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 05-12-2004, 07:21 AM
Bazzle Bazzle is offline
Default Re: Wave driver/ASIO driver
Wavelab works I/O with the ASIO..Go to Options>Preferences>Audio card and select Digi ASIO from the drop down list...
Wavelab can convert it any way you like..I like to do the final conversion in Wavelab.
You can set the Wavedriver as Default in system if you like.remember the Wavedriver is play back only in 6.4
Bazzle
Old 05-12-2004, 07:45 AM
clausiii's Avatar
Thanks for your reply Bazzle!
The ASIO driver doesn´t work too @ 48/24. That´s my problem! Both drivers do 44.1/16 only!
Haven´t tried out, what the Windows Media Player does with 48/24 files, but when I hit play in WL, Wavelab opens an error message like "this sample rate is not supported or another application uses the driver" or something similar...
My ears! My ears!
clausiii
ProTools 2019.5
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 05-12-2004, 08:00 AM
I never use 48/24 but Wavelab will play back through the ASIO 44.1/24..When you open the new file you have to set the audio properties.Same thing when you record.The ASIO supports 96khz/24 bit as does Wavelab..
For fun I just recorded through the ASIO into Wavelab 48/24, it worked fine both I/O.
Maybe another app has a lock on the ASIO make sure all apps release it when not using it.
Bazzle
Old 05-12-2004, 06:15 PM
lemix's Avatar
lemix lemix is offline
Good point... PT LE maybe???
clausiii >>
One cannot use ASIO signed apps with PT running !
cheers,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 05-12-2004, 06:20 PM
To get the ASIO driver in WaveLab to "take" can be tricky.. do a search on the DUC where this was previously discussed.. some users weren't getting the ASIO driver in WaveLab to "take" because of the way the pull down menu in the WaveLab prefs works.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
ASIO/Wave Driver help scottgreiner Pro Tools TDM Systems (Win) 4 08-28-2010 11:38 PM
Asio driver and wave driver.. Help!!!!!!! bzncokr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-26-2009 05:12 PM
WAVE Driver / ASIO Driver Tomio Broman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-25-2007 11:38 PM
ASIO or Wave Driver Jerry K. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-09-2003 08:15 AM
Asio and Wave Driver git1song 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-22-2002 10:55 AM
