New Mbox Pro problem with preamp pots?
So I finally got my new Mbox Pro, hooked it up, got it running through pro tools without any issues. however, when i started testing the pre amps, i ran into something interesting.
When i turn the pot level hotter, it will very gradually increase the volume, but remain pretty low, this part is fine. but when it gets just before being maxed out, the volume signal jumps pretty drastically. I'm not really sure if this is how it is suppose to work or not, it just seems odd that it has such a drastic change at the very end. I tried playing around with the -20db pad and it seems to do the same thing, just jumps pretty drastically in volume right near the end of its range. anyone else notice this? is it suppose to do this or is something off? Thanks guys |
Re: New Mbox Pro problem with preamp pots?
Don't know why this happens, but it happens on many units besides the Mboxes. Maybe that's why I hate using the last bit of "knob". Personally, I rarely have to turn GAIN knobs past halfway(if I do, then I search for a problem). Most cheap to mid-priced preamps get too noisy at the top of the GAIN setting anyway
HP Z4 workstation, Mbox Studio https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix BTW, my name is Dave, but most people call me.........................Dave Last edited by albee1952; 06-12-2013 at 02:06 PM. |
+1
PT 9.0.3 Windows 7 64 bit, 2x i7 PCs, 24GB, 3 SSD's, 5 HD's ....and a couple other toys. |
I have noticed the same gain bump on other preamps as well but nothing as drastic as the new Mbox. My problem is the volume is way too low or if I past the bump it's way too high. I cannot get enough gain out of a nice condenser without turning up the preamp 90% or higher.
No the -20 db pad is not engaged. I record fine all the time in my PTHD with my Millennia preamps and my 96 i/o. I am just trying to help a friend diagnose his low level problem. Ideas? |
I just purchased the MBox3 mini. I Mic my amp at the grill cloth(SM57) and Xlr's on both ends, into input 1 on MBox. I have to turn my amp up more than a comfortable level and the gain on the MBOX to 3/4 to get proper input level. This does not seem right .Then after about 3/4 get over drive. Anyone else have same issue?
Don't know about the Mini but if that was a normal mBox 3 it would sound like you have the Pad on.
Are your Gain Knobs pushed in or pulled out? I have a mBox 2 and a mBox 3, Gain setting half way with no Pad is basically the same on both units. The big difference to me is in the clarity not the level.
URBAN MUSIC- (Hip Hop and R&B) |
Also what are your levels set for in the mBox Control Console?
did you find a solution for the mbox3 pro levels of input 1 and 2
i got the same , and can't find a solution thanks in advance |
What guitar amp and cab? What type of music are you playing/what tone are you going for? Unless you are after super clean tones most amps are going to be recorded at reasonably high sound levels. What do you mean "to get a better waveform" ? If the volume is set about half way on the mic preamp how does the recording playback *sound* (not "look")? We cannot help much with comparisons like "totally different", totally different how? How are you monitoring this back to make the comparison, what monitors/speakers or headphones. (That is always going to sound different than the live amp in the room). Post a sample to Sound cloud, especially if you think the recording has an outright problem. Do you have a second mic to try? How does this mic sound if you use it for vocals? |
Calibrating Trim Pots, Pots not responding | D-Street | Pro Tools TDM Systems (Mac) | 9 | 09-04-2010 10:01 AM |
Strip Preamp with Mbox problem | oettinger1919 | General Discussion | 4 | 12-09-2009 05:14 PM |
Mbox preamp/ new preamp | Antihero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-23-2003 07:31 AM |
Mic Preamp Problem | cody | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-10-2002 02:56 PM |
mic preamp problem | [email protected] | Pro Tools TDM Systems (Mac) | 2 | 08-14-2000 07:36 PM |
