Old 01-21-2006, 06:33 AM
Acle Acle is offline
Default Driver problems with 002 rack + nuendo problem
Hey peeps, hopefully someone can help me with this one!
I've jsut formatted the computer to clear everything up. Before the format i use either the 5.3 or 6.1 drivers for the 002 rack with no service packs on XP installed!
I've now installed XP with all the service packs and updates etc. I installed the 7.0 drivers. Works perfectly and now I can use a 2048 buffer size finally (i use a lot of plugins) However previously i used to use the "direct monitoring" option in nuendo/cubase. Enabling this now however results in no send when I go to monitor a track. If i disable direct monitoring then then the sound appears but obviously it is delayed....i'm used to the 0ms of direct monitoring Any help ?!?
I tried reverting and installing drivers 6.1.1 and a 5.3 one i have. However as soon as i load nuendo up with these the computer just decides to restart itself. So im pretty ******!
Please any ideas?! I'd much rather use version 7 drivers...have they got rid of direct monitoring or am i doing some wrong?
(edit)
When i use the old 5.3 drivers i cant select the digi 002 as an ASIO driver...
Anyone know what might be causing the computer to restart itself with the 6.1.1 drivers? I get the same problems in nuendo 2.01, 2.2 and nuendo 3
Thanks!
Acle
Old 01-21-2006, 07:26 AM
spkguitar's Avatar
Default Re: Driver problems with 002 rack + nuendo problem
I don't know about the direct monitoring part in Nuendo, but you shouldn't load the old drivers over 7.0, that will definitely muck up the whole works.
The rebooting problem, I beleive, is and issue with SP2 and the old drivers.
Old 01-21-2006, 01:19 PM
yeah i uninstalled the version 7 drivers first of course then tried it. i've found out that i get the same problem with my maudio delta 66....no direct monitoring (unless i pump it thru the control panel in the delta box) but i should be able to use the monitor button to do it like i used to :S
guessing its more a nuendo setup or comp problem as opposed to sound card now
Asio problem - Digi003 Rack - Driver vs9.0 Lessandro Windows 48 05-17-2012 02:49 PM
003 Rack Factory problem with Driver m1a Windows 0 11-14-2011 08:54 AM
standalone driver problem with digi 002 rack mirok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 11-02-2007 06:15 AM
002 Rack driver problem Nathan002 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-21-2006 02:43 PM
Disi002 Rack driver problem rnygren 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-08-2003 01:35 AM
