Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Closed Thread
Old 10-14-2020, 01:12 PM
2023speaklife 2023speaklife is offline
Default iLok not working
one day I using protool and I ilock stop being recognized so I bought a new one and I end up with the same problem... I restarted and reinstalled still not working
Old 10-14-2020, 10:14 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: I ilock not working
Have you got the latest ilok manager installed?
Can you view the contents of the ilok and see your pro tools license using the ilok manager?
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-14-2020, 10:38 PM
And to add to what Chris said...
Just buying a new iLok won't help you. The encrypted license key is on the old iLok. An empty iLok by itself won't do anything, except maybe verify you can read it with ILM (iLok License manager). You can install a replacement license on your new iLok once Pace has the old dead iLok you send them and they deposit a licenses back into your iLok.com account.
If the iLok with your license key on is is broken/not working you need to go through the recovery process documented on iLok.com. And if you have not subscribed to Zero Downtime now is the time to read up on that on iLok.com.
Try the latest iLok.com, reinstall it even if you have the latest, and try multiple USB ports.
Old 10-15-2020, 07:46 PM
sw rec sw rec is online now
Did you disable usb power management?
Old 10-15-2020, 10:20 PM
jeffro's Avatar
jeffro jeffro is offline
Welcome to the community.
Your iLok account shows that your Pro Tools Perpetual license is in your iLok Cloud. You should sign into iLok License Manager and Close Your Cloud Session then activate the license to your iLok. Also, make sure you are running a version released on/before the Release Limit date (Show Details for the license and find supported versions here).
linkedin
Old 10-16-2020, 02:52 PM
I didn't I don't know what happened
Old 10-16-2020, 02:53 PM
I know that I moved it there because my ilock wasn't working all the time
Old 10-16-2020, 02:55 PM
Originally Posted by crizdee View Post
Chris
I have the lastist version, yes
I have tried everything all the above
Old 10-16-2020, 03:23 PM
But all this is a waste of time, as Jeffro points above... if you moved your licenses to the cloud, it won't be on you iLok, it will have been removed from the iLok and is now "in the cloud". Kinda a basic point. But if you did not do that, can't do what he suggests, please reply to his post.
Closed Thread
ilok working on new MBP with usb 3 stevedresser83 macOS 8 11-21-2013 08:41 PM
Strike 1.5 upgrade - not working because of iLok-working now gryphondale Virtual Instruments 0 01-27-2008 09:23 AM
ilok working? detroitkruk Pro Tools TDM Systems (Mac) 5 08-02-2005 07:24 AM
USB / ilok not working blizzard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 12-31-2004 07:08 PM
ilok driver not working on brand new ilok, help! joybeanstudios Pro Tools TDM Systems (Win) 2 05-30-2004 09:40 AM
