Old 03-11-2014, 10:27 PM
dbiscuit dbiscuit is offline
Default HD I/O thunderbolt (digital distortion playback)
early 2011
macbook pro
2.2 GHZ Intel Core i7
4GB RAM
OS 10.8.5
Protools 10.3.8
hd driver 11.1
HD native thunderbolt FPGA firmware 2.01
HD I/O firmware 5.5
Kingston SSD internal
Lacie external HD (firewire 800)
Issue:
Had the system configured with a Hitachi internal. OS 10.9.1, PT 11.2
Gradual decay of signal until completely garbled. Almost like 2 bit
playback of everything in or out. Device is seen in Avid core audio, as
well as playback engine.
Step Taken:
1. Replaced internal with known good SSD
2. Played back project (external) on another users MBP
3. Uninstalled HD Driver
4. Reinstalled HD Driver
5. Digitech updated firmware and passed tests. Device shows up
in playback engine. Audible pop when opening project.
6. Replaced thunderbolt cable.
7. Replaced Digilink cable.
8. Tried every possible starup sequence i could think of
9. Wiped internal drive
10. Installed clean OS 10.8.5
11. Installed Pro Tools 10.3.8
12. Tried a different external firewire drive
Results:
No improvement. At some stages the device would appear to work
normally only to gradually decay again into a munged basket of
nasty. It appears that there might be a clocking related error. Or
perhaps a degraded chipset in the thunderbolt box or the I/O.
Conclusion :
I need a new HD I/O
PT 10 & 11 HD Native Thunderbolt not recognised as default Playback Engine aperez Pro Tools HDX & HD Native Systems (Mac) 7 07-26-2015 07:41 AM
Digital Distortion On Playback howilostmyway Pro Tools M-Powered (Win) 2 07-30-2007 07:04 AM
digital distortion ventjw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-06-2005 03:20 PM
Digital Distortion with 001 Nick Rogers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-28-2004 11:09 PM
digital distortion qgrm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-24-2004 09:23 AM
