Old 01-28-2016, 09:16 PM
mecklot mecklot is offline
Default "Could not complete your request because The system cannot find the file specified."
Hello all,
When I opened up one of my projects, Pro Tools told me there was a difference between my local file and the cloud file. I chose to open my local file and worked off of that. When I saved, Pro Tools said it would overwrite the cloud file, which I had no problem with.
When I tried to open up the same project, I got this error message:
Could not complete your request because The system cannot find the file specified. (2) c:\Users\Phil\Documents\Pro Tools\Project Cache\KKBsggSpcb5RwB5gcYk_nb\N_ZYNdGAcr7PcCtsWbCOl a.ptproject\Revision History\Manual Saves\0065.ptpx.
The "0065.ptpx" file does not exist. Opening the latest auto-backup nets me the same message above. I tried logging back in, restarting Pro Tools First, and restarting the computer, but no such luck.
Computer Model: TOSHIBA TECRA Z40-A
OS: Windows 8.1 (x64)
Processor: Intel i3-4030U CPU @ 1.9 GHz
RAM: 8 GB
Audio Interface: ASIO4ALL v2
Pro Tools First 12.3.1
Old 01-29-2016, 01:39 PM
DigiTechSupt's Avatar
Default Re: "Could not complete your request because The system cannot find the file specifie
Hello mecklot,
Be sure that you have special access to folders where the project is save.
Regards,
RC
Avid Audio Tech Support
Support FAQ
Old 12-12-2017, 09:05 PM
gritcheese gritcheese is offline
Been working on this song for 3 months and since yesterday,
i cannot open it anymore. I get a similar message:
Could not complete your request because The system cannot find the file specified. (2) c:\Users\Bakana\Documents\Pro Tools\Project Cache\2mtp5pIXpXiKeaClAv8tzb\J8jaPusnhb7GJ0uvIWwdL c.ptproject\Revision History\Manual Saves\0159.ptpx.
Unless i do not understand what that means, i have full access to all my folders. So i am stuck. anyway way to fix this,or restart from scratch?
Pro tools first ---Focusrite scartlett i6
Intel(R) Core (TM)
i5-7200 CPU @ 2.50 GHZ 2.70 GHZ
12 GB RAM
64 bit operating system
windown 10 pro
Old 12-14-2017, 11:16 AM
junkgear's Avatar
junkgear junkgear is offline
In file explorer, try to navigate to the folder shown in the error message. If you can open the folder and see the ptpx file, then folder permissions are not your problem. If you get an error trying to open the folder, then something has changed on your system and you will have to take ownership of the folder to allow PT to access the project cache.
Will
System Details
Old 12-14-2017, 11:48 AM
Southsidemusic's Avatar
He is on PT First so maybe something has changed in the settings.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-14-2017, 07:10 PM
thanks for reply, junkgear, i can get access to the folder...
and yes southsidemusic i am on protools first, and
yea probably a change in the settings, no clue
maybe a glitch.
Old 03-12-2018, 03:18 PM
PValois PValois is offline
I'm receiving the same message on one of my projects that was nearly completed. Extremely frustrating. Projects are lost in the cloud I guess???
Old 10-05-2018, 08:53 AM
gazmitch gazmitch is offline
lots of good information here thanks guys, I'm still learning very helpful
"Could not complete your request because Access is denied" ColinSound Windows 2 05-13-2013 02:58 PM
FIXED: Startup issue: "Could not complete request because Assertion line 1424" wheret Windows 2 07-11-2012 05:43 PM
Error message "could not complete your request because..." on PTLE 8.0.3 load up blast9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-02-2010 02:49 PM
"could not complete your request because end of stream encountered" PT8 promblem nikokarpaasi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-22-2009 12:49 AM
"Cannot complete request... Access violation occured" jonnyb8390 Pro Tools TDM Systems (Mac) 0 01-07-2009 12:39 PM
