Old 05-11-2005, 08:48 PM
riotbeats riotbeats is offline
Default how do you erase all automation?
I want to erase all automation from all of the tracks on my song. I usually do this by selecting all tracks as "write" and then playing the song but there must be a faster way to do this. Thanks in advance!
Allen
Old 05-11-2005, 10:07 PM
malfunction malfunction is offline
Default Re: how do you erase all automation?
just select everything with the cursor then press delete...
PT9, Zed R16 & Macbook Pro i7 2.66Ghz
Old 05-12-2005, 12:49 AM
Paul Maunder Paul Maunder is offline
Try this: Select all the audio on the timeline using Command+A, then from the edit menu select 'Write Automation To All Enabled Parameters'. This will then flatten all of the automation across all tracks for all currently automatable parameters. There are a couple of slight draw backs to doing this: Firstly, it will use the initial value for any given parameter on a particular track as the value to use throughout that track. So if a tracks volume was at -10dB at the start of the timeline, that value would be carried across the whole length of your selection. Or if a track was muted at the start of the timeline selection, the mute would also be written across the whole duration of your selection. The other slight draw back is that breakpoints will be added across ALL parameters at the end of your selection, which could be time consuming to get rid of. Thinking about it, maybe this method isn't that great. Since I've already typed this though, I'll post it anyway
how do you erase all automation parameters at once? Anibal Pro Tools TDM Systems (Mac) 11 05-04-2018 05:33 PM
REALLY erase a FW drive KamaSutra77 Pro Tools TDM Systems (Mac) 9 11-07-2002 06:35 PM
Mute Automation Inquiry-- Match, extend, erase etc.. Mt.Everest Pro Tools TDM Systems (Mac) 2 09-16-2002 02:54 PM
How to erase CD-RW with Toaster Wong Chee Seong Pro Tools TDM Systems (Mac) 5 07-13-2001 08:00 PM
Erase All Automation felixstone Tips & Tricks 1 03-06-2001 12:38 AM
