Old 07-23-2017, 05:59 AM
Stef1342 Stef1342 is offline
Default Focusrite Scarlett 18i8 - High pitched, faster recorded issues
Good afternoon,
I've recently purchased a Focusrite Scarlett 18i8. I've installed the drivers as (Focusrite control 2.1.7 and Focusrite USB4.36.0.484). When recording in Protools 12.7.0 I experience warped playback (high pitched, sped up). Even if I'm not recording, if I have the track record enabled there is a slightly distorted sound.
I'm a little stuck as to what might be the cause of the problem. I've tried reinstalling the drivers. I've tried a couple of sample rates (44.1, 48, 96kHz) with multiple buffer sizes.
If anyone has any ideas or has experienced this issue before please let me know. I'm at my wits end!!
Thanks,
Stef1342
Old 07-23-2017, 09:41 AM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Focusrite Scarlett 18i8 - High pitched, faster recorded issues
Hi sounds to me like other app is taking control of the driver while using PT .
Maybe windows .? Check sound panel and verify that the Focusrite isnt the default playback device for windows while using PT .
Also check what others app are running in background and make shure to disable them at startup . ( You want avid and, ilok services only running here , at least for troubleshooting )
Let us know !
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 07-23-2017, 01:31 PM
Hi Jeam25,
I checked. The focusrite had been set as the device used for windows so I've changed that. I've also checked the start up apps as you recommended and disabled anything that may use sound. Unfortunately this hasn't resolved the problem!
Thanks for the suggestion though. Much appreciated!
Stef1342
Old 07-23-2017, 01:45 PM
Try setting the sample rate in the Focusrite Control software and then start Pro Tools with a session at that same sample rate.
If pre-existing/previously recorded content is at the wrong sample rate for a session you need to import that into the session with sample rate conversion applied.
Old 07-23-2017, 02:34 PM
gonsdeejay's Avatar
gonsdeejay gonsdeejay is offline
Try To Run Pro Tools holding "N" key just after Pro Tools Logo appear, then after several seconds depend on how many plugins are installed, will appear Playback Engine dialog, There just grab another Audio Device different to Focusrite, after that, before open a session, go again to settings and chose your scarlett again, maybe that resolve your playback issue!!!!
Pro Tools 2021.12 UAudio Apollo X8, 8 Duo & Apollo Twin. Mac mini M1 8 on Ram, 256gb, Thunderbolt 3 KRK V88. Yamaha HS7 Korg ESX-1 MBOX2 003Rack Producing My Own Life
Old 07-24-2017, 01:16 PM
Thanks Darryl Ramm and gonsdeejay. I have tried both but unfortunately haven't had any luck. Thanks for the suggestions! I'll keep working on it and let you know if I manage to resolve the issue.
Old 07-24-2017, 01:20 PM
jeam25's Avatar
Hi ! Sorry to hear that . Also check what device is controlling your word clock ? And what number is it set ?
Protools Ultimate
Old 07-24-2017, 03:45 PM
jeam25's Avatar
Also i remember helping somebody with a Scarlett sometime ago and I read somewhere that Focusrite recommend to disable Fast Boot on windows 10 for sclarlett . Do you have this setting Turned OFF ?
Here how to do it !
Protools Ultimate
Old 07-25-2017, 08:34 AM
Matthew.Focusrite Matthew.Focusrite is offline
Hi Stef1342,
Sorry to hear about the playback issues using the Scarlett 18i8 with Pro Tools, but we are more than happy to help. First, please take the time to go through the appropriate Avid optimization guide for your system found in the following link:
http://avid.force.com/pkb/articles/e...oting/en367983
After implementing the listed steps, please proceed with closing any additional background applications and verify the device is not selected in the Windows sound properties. When launching Pro Tools, it is recommended that the program is ran as an administrator. Once opened, please test further to verify if issues are still present.
If you are still encountering difficulty, please feel free to contact us through the following link so we may investigate further:
https://support.focusrite.com/hc/en-gb/requests/new
Old 07-25-2017, 02:22 PM
Hi Jeam25,
Please excuse my ignorance but my word clock? :S
And yes I read that focusrite recommend that to therefore I had already disabled it. Unfortunately that hasn't solved the issue. I've also just uninstalled and reinstalled pro tools in the hope that it may resolve the issue but again it hasn't. When I plugged in my old audio interface the same issue is occurring so I'm really confused now!!
Thanks,
Stefan
Interfacing Issue with Focusrite Scarlett 18i8 UberAubergine Pro Tools 11 2 06-04-2019 08:46 PM
Crackles and Pops in PT 11.2.1 w/Scarlett 18i8 BassGuyGG Pro Tools 11 1 04-06-2017 11:18 AM
Focusrite Scarlett 6i6 issues bootyt FireWire & USB Audio Interfaces (Mac) 2 12-12-2014 03:03 PM
Focusrite Scarlett 18i8 kyluigi Third Party Interfaces 6 10-17-2013 08:14 AM
Song sounds faster and high pitched after bounce. Abel0470 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-12-2013 08:45 PM
