Pro Tools hardware is either not installed or used by another program
Every time I load up my Pro Tools is pops up with 'Pro Tools hardware is either not installed or used by another program'. I am trying to use my Edirol UA-25 sound card via asio4all. I have had this setup working before and i have no idea why this keeps on popping up. Currently i have my UA-25 as default device on my playback devices but i have had the UA-25 as a communication device while internal sound card is default device.
I have also tried re installing pro tools, re installed UA-25 drivers and delete the preference trash files. Any Ideas guys? Also to do you have to buy a Avid support code if you want to call Avid's costumer service? |
Re: Pro Tools hardware is either not installed or used by another program
I doubt they would be able and/or willing to help much since you're using a 3rd party interface. Try checking in the Control Panel your Sound settings for the Edirol. Double-click your default playback device and go to the Advanced tab. Set your sample rate to the one you need for Pro Tools, and make sure "Allow applications to take exclusive control of this device" and "Give exclusive mode applications priority" are unchecked. Good luck!
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
pro tools hardware is either not installed or used by another program- can't fix it | drorsh4 | Pro Tools 9 | 11 | 04-25-2017 05:57 PM |
Pro Tools hardware is either not installed or used by another program | kristiankristian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 03-27-2014 07:19 PM |
Pro Tools Hardware is either not installed or in use by another program | f.judice | Windows | 6 | 04-05-2012 08:33 AM |
'Pro Tools hardware is either not installed or used by another program' | thedeeviant1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-19-2009 03:01 PM |
Pro Tools hardware is either not installed or used by another program | kristiankristian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-06-2008 09:54 AM |
