Old 12-30-2010, 01:44 AM
BobTheDog BobTheDog is offline
Default Eleven Rack FX Loop - Terrible hiss if placed before amp
Hi Guys,
On my Eleven Rack if I place the FX Loop before the amp I get terrible hiss, really bad.
After the amp no hiss, totally silent.
It is like this even with nothing actually physically connected to the send/returns!
It basically makes it unusable, is this normal?
Thanks
Andy
Old 01-04-2011, 06:25 AM
Default Re: Eleven Rack FX Loop - Terrible hiss if placed before amp
Anyone?
Old 01-04-2011, 09:14 AM
59tweed 59tweed is offline
Location: Northern tip of the gorgeous Wasatch mountain range
I don't use equipment in the loop, and am generally inexperienced as such. Still, I will try to get the ball rolling, and perhaps someone more knowledgeable will pop in.
Have you tried removing the gear from the loop to see if it hisses? I tried it and I don't get a hiss, but that is with generally lower gain settings. So, if you are getting a hiss without any gear in the loop, you may have a setting that's kicking out all the noise, or less likely, a hardware failure. Of course, if the hiss goes away without the gear in the loop, you'll to trouble shoot in the other piece of gear.
a.k.a. crazyForce
Old 01-04-2011, 09:30 AM
Thanks for the reply.
The hiss is there when there is no gear in the loop.
When you tried did you have the noise gate off on the amp?
Cheers
Andy
Old 01-04-2011, 09:34 AM
Here is a test.
1. go to the factory preset a1
2. Turn the noise gate off in the amp
3. Turn fx loop on
4. set fx loop mix to 100 %
So now we have no noise at all
Now:
5. Move the fx loop in front of the amp
I now get loads of hiss
Cheers
Andy
Old 01-04-2011, 09:38 AM
Not in a place to do those now. I will try to remember to check this and report back later today. Is this a setting which you would use in normal use?
I usually don't use a noisegate. But when I do, I normally have the threshold set at around 77 so that there is no extraneous noise when I hold the strings still, but a subtle stroke will still come through.
a.k.a. crazyForce
Old 01-04-2011, 09:40 AM
That would be great, thanks very much.
It is driving me mad, I am sure when I first got the eleven rack it did not have this noise.
All the best
Andy
Old 01-04-2011, 11:40 AM
fastart fastart is offline
I get the same thing. I tried to put a vol pedal in the loop but there was so much hiss I had to take it out an try some other way of hooking it up.
I was looking for a different way to use the vol pedal other than connected thru my midi controller because i dont like the way the 11r saves its position in the patch. The vol pedal should work in the position its in, not in what position the 11r thinks it's in.....
I did have a wah in the loop before and didn't have a prob with it tho, so why would a vol pedal cause it to hiss?
Old 01-05-2011, 12:14 PM
TheChimp's Avatar
TheChimp TheChimp is offline
Check your FX Loop User Option and make sure the Mono, Mono-Stereo, Stereo setting is correct for your setup. It's possible that what you're hearing is the 'empty' side of a stereo FX Loop, which is then being amplified by the amp (when placed pre-amp).
_______________________________
The Chimp
Delivery Manager/CSM, Guitar Products/AAX Plug-ins
P&S Creative Professional
AVID
Old 01-05-2011, 12:45 PM
Are you saying then that even without anything in the loop I may get hiss if the fx loop is on as there is no return signal?
This seems strange?
Cheers
Andy
Eleven Rack and G major 2: help! (FX loop) Schromeo Eleven Rack 5 01-07-2014 12:24 PM
Eleven Rack with Lexicon PCM92/96 in loop or in AES/EBU I/O dayslypper Eleven Rack 10 10-17-2011 05:06 PM
003 and Eleven Rack - Digital hiss when rec arming SPDF tracks kkguitar macOS 1 10-11-2011 09:42 PM
Can the Eleven Rack loop work with plug-ins? manatarms Eleven Rack 3 04-06-2011 12:51 PM
Eleven Rack Hiss when using live philster65 Eleven Rack 4 11-29-2010 09:08 AM
