Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 10-27-2017, 05:03 AM
Rockman413 Rockman413 is offline
Default If I use a crap HD to copy audio files, would it cause any problems?
Hi there,
Just wondering if I use a crap/old/ may have hit/ may have bad clusters/may have bad blocks hard drive to copy pro tools session/ audio files to another computer, will the receiver got affected/damaged audio files?
Is it as long as we can read/copy out from the crapped hard drive, then it's fine?
I have used an USB stick to copy audio files and I occasionally found 1 audio file got affected/damaged, half of that audio file turns into white noise... Not sure if it's the same with hard drive
Mac Pro 3.0G 8 Cores PT HD use with Ensemble Thunderbolt
Last edited by DigiTechSupt; 11-04-2017 at 06:42 PM. Reason: Duplicate threads merged and moved to appropriate forum.
Old 10-27-2017, 05:24 AM
Horns-Up's Avatar
Horns-Up Horns-Up is offline
Default Re: If I use a crap HD to copy audio files, would it cause any problems?
If the disk is old but fully functional, then go for it...
BUT
If you know that the disk may have bad sectors, do yourself a favor and throw it away. Disks are so cheap these days that it's not worth it to have your data (any data) corrupted.
You can get a 2 TB disk for about $60 on Amazon... put it in some USB enclosure and there you have your disk to transfer your sessions from one location to another.
Chris M.
Horns-Up
- Mac Pro (Mid 2010) - OSX 10.13
- Pro Tools 2018.4
- Apogee Ensemble - Firewire
- Eleven Rack
Old 10-27-2017, 05:50 AM
BUT
How about SSD? Would a old/may have hit SSD cause any corruption?
Old 10-27-2017, 06:23 AM
Horns-Up's Avatar
I got my first SSD back in 2008-2009 and it is still working perfectly fine.
I've been using it for different purpose over the years and it's quite possible that is has some bad sectors...(never checked it)
SSDs work a bit different than regular HDDs...
SSD can totally tolerate bad sectors because the firmware of the SSD keeps track of all bad sectors and will never write any data to those sectors.
If you are on windows you can use chkdsk or Disk Utility on Mac.
Chris M.
Horns-Up
- Pro Tools 2018.4
- Eleven Rack
Old 10-27-2017, 07:22 AM
meaning, if it has been written already, then a already-written sector turns bad, it will not be readable? Or it will still be readable, but you're going to get incomplete info/ corrupted audio?
Old 10-27-2017, 07:32 AM
JoelG's Avatar
JoelG JoelG is online now
Short answer, do yourself a favour and don't use a drive that has known bad sectors.
You can use a program to check the SMART attributes of a drive: https://www.passmark.com/products/diskcheckup.htm or run a full scandisk.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 10-27-2017, 05:55 AM
BUT
What's the best HD check soft? So maybe we can check if we suspect a HD
Old 10-28-2017, 09:55 PM
Oh God, why is this thread still going on. Just copy the files. If you had experiences where things did not seem to work then try to work out what happened. The most likely problems are mistakes like copying files not fully written to disk (e.g. Pro Tools session not closed before you copy), the disk not being properly unmoubted, or an application bug in Pro Tools.... silent filesystem or disk block level corruption are not worth worrying about. Deep corruption you expect copies to fail. But if you don’t have confidence in a drive trash it.
Old 10-29-2017, 05:32 AM
The thing is, I just bought a new drive about 2 months ago , but it hit the floor , not a big deal thought but still some concerns. That's why I wonder if I continue use this one and if the copy process if complete without any errors, am I getting exactly the same audio files. That's why I start this topic to really understand how it works and if we can trust a complete copy process means we are getting the identical files.
Old 10-29-2017, 05:38 AM
Furthur more, I have had an experience of copying audio files to a very very cheap USB stick , and to another computer, and I got half of the audio turns into white noise... It may be damaged due to unmount...
So wondering if a super cheap USB stick, which may easily have bad blocks, once the copy is finished without any errors, can we really trust all the audio files are the same as original.
Missing Audio Files in Session Copy jshiffma Pro Tools 12 5 06-20-2017 03:43 AM
Save Copy as without Audio Files force76 Pro Tools 11 3 11-20-2014 09:06 AM
How to copy audio files not in session folder? jchan macOS 2 04-18-2014 05:29 AM
Help! PT wants to copy all audio files PT10-PT9 evs Post - Surround - Video 2 07-23-2012 12:17 PM
How do I copy and paste audio files? tioluis Pro Tools TDM Systems (Mac) 4 07-01-2007 10:22 AM
