Old 01-08-2019, 05:19 PM
Southsidemusic's Avatar
Default Re: The o'l CPU overload/increase H/W Buffer Size (error AAE-6101)
Originally Posted by xrekcor View Post
ok that good to know.... perhaps some conflict with the TF5. did you run High Siera on those machines error 6101 free?
I said Mojave in my post!
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 01-08-2019, 05:25 PM
xrekcor's Avatar
xrekcor xrekcor is offline
yup saw that, sorry meant your 2014 MBP.
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 01-08-2019, 05:26 PM
That was Sierra 10.12.6
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 01-08-2019, 05:31 PM
xrekcor's Avatar
Ok, well maybe I should consider making that move to Mojave since I haven't heard any bad reports of it yet. albeit Ill do a lil research and back up an image of my internal first. I've been holding off for a while... thanks for responding Chris
Rob
Old 01-09-2019, 01:15 AM
Emi's Avatar
Emi Emi is offline
Also try to disable hyperthreading. That helps a lt.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
  #16
Old 01-09-2019, 04:22 PM
xrekcor's Avatar
I downloaded CPUSetter yesterday, currently testing..... get back to ya
Rob
  #17
Old 01-09-2019, 11:33 PM
Emi's Avatar
Emi Emi is offline
Mind you, yesterday while working I had a 6101 error. And just found out there was an Ilok app manager update (that trigs errors, that’s a real issue Avid and ilok have to solve).
I also set an alarm to trash prefs once a week, and another to look for ilok app manager upadates.
  #18
Old 01-10-2019, 01:25 AM
xrekcor's Avatar
Ok iLOK updated.... thanks for the heads up. I’ll see how we travel with that updated..... turning off hyperthreading seemed like there was a slight improvement, hard to say... but still got three prompts over 6-7 hours the first one came in 50 minutes. For a while there, well the last couple of hours I had Activity Monitor>CPU and PT’s System Usage running to catch what going if it threw a prompt... but didn’t.
How difficult is it to trash prefs?
Rob
  #19
Old 01-10-2019, 01:29 AM
Not hard at all
https://www.sweetwater.com/sweetcare...s-preferences/
Best Regards
Christopher
#thestruggleisreal
WEBHOME
  #20
Old 01-10-2019, 02:02 AM
xrekcor's Avatar
Cheers Chris, so it is....
Thanks mate
Well with iLOK updated hyperthreading off.... and a play through of first session after starting PT o’l 6101 threw again.... and the CPU Load in the Activity Moniter showing it spiked barely 15% PT sys usage CPU Total 2% and 1-6 sitting at 1%, disk at 1%, memory at 6%
Rob
Increase buffer size Error.. -_- .. changareth macOS 4 02-09-2011 08:50 AM
Increase Buffer Size Error (Buffer at MAX) ??? PoPimp3069 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 03-29-2010 02:24 PM
increase H/W buffer size error dgrim 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 07-08-2009 04:50 PM
Increase buffer size error toddw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-19-2008 02:05 PM
Help! "Increase Buffer size" error therigaletto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-17-2008 05:25 PM
