Old 01-20-2019, 03:08 PM
briaboy briaboy is offline
Default tracks/channels out of time with each other
Hi - I've been working on a particular song for a few weeks. I opened it up today, and several of the recorded tracks are completely out of time with each other. e.g. the click and the vocals are in perfect time, but the bass, piano (VIs), etc. tracks are playing at least a bar behind them. The waveforms in the edit window seem to have shifted. No idea why/how this has happened. The entire piece was in perfect timing and alignment when I was working on it just a few days ago, and none of my other PT-recorded songs are affected. Any thoughts? Thanks!
Using PT 2018 with UAD Apollo 8.
Old 01-21-2019, 11:58 AM
Default Re: tracks/channels out of time with each other
Some things to try:
1-open from the Session Auto-backups folder and see if a recent version opens and plays in time.
2-disable, then enable Delay Compensation(Options menu).
3-check your midi settings to see if you accidentally set a midi offset.
4-make all sends inactive and test. If this allows everything to play in time, search for a send that goes nowhere(which can confuse Delay Compensation).
Old 01-21-2019, 12:52 PM
Thanks, I'll try those excellent suggestions!
best,
bb
Old 01-22-2019, 03:50 PM
xrekcor's Avatar
xrekcor xrekcor is offline
there wasn't an accidental change of tempo that can mess things up especially midi files against audio files that will remain the same.
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 01-22-2019, 05:13 PM
There was indeed, plus the samples somehow changed to ticks. No idea how or why! Fixed now. Thanks for all your help!
Expand channels to new tracks crashes every time colinato Post - Surround - Video 2 07-20-2016 02:01 PM
how do i record 16 midi channels at the same time???pt7.3.1 safehouse10 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-30-2007 01:04 PM
recording 18 channels with 002 at the same time BrianH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-30-2006 04:17 PM
"This plugin only process 47 channels at a time " Blackfoot Pro Tools TDM Systems (Mac) 8 03-24-2004 01:19 PM
This plug-in only processes 47 channels at a time. AS in PT6??? Inaam Pro Tools TDM Systems (Mac) 1 03-13-2003 11:03 AM
