Vocal Chains
Hey guys. can some of you help me out. i need to know what are some good vocal chains to help me get clean clear vocals within the pro tools plugins such as comp, reverb, desser, eq. thanks. the more you guys can give me the better, that way i can try them out.
HP Pavilion p6620f PC Windows 7 Home Premium 64-bit AMD Phenom II 820 Quad-Core Processor 8GB DDR3 system memory 1TB hardrive memory ATI Radeon HD 4200 intergrated graphics Pro Tools 9, FL Studio 11 Producer Edition Mbox pro 3rd Gen, Mbox mini 3rd gen M-Audio Axiom Pro 49, Novation mini nova, M-Audio AV 40 Monitors, M-Audio BX8a monitors, M-Audio NOVA Condenser MIC, AKG Perception 220 Microphone, Rode NT2a, Avid Artist Mix, Avid Artist Control, NI Maschine, Glyph GPT50 3tb |
Re: Vocal Chains
Good sounding vocals start with a good mic, a good preamp, and a good room.
From there, there's not a lot of work to do. Some compression, possibly some EQ.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack | |
Re: Vocal Chains
I bought smack (compressor) and tl space on evilbay for cheap. They improved my vocal chain alot. I use the digidesign generic eq. i heard the Sony oxford eq is the bomb if you can afford it. Uad cards have excellent plugins also.
Diddo on Good mic/good pre/acoustic My chain is Beyerdynamic mc740>Neve Portico preamp>apogee ensemble> pro tools I just got a se reflection filter for acoustic control. It sounds so much better and clear. I highly reccomend it! |
Re: Vocal Chains
Best to keep the talent on a short leash.....
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Re: Vocal Chains
ok let me make my self clear on this. First i do compression on my vocals then vocal deesser, then vocal expander, then eq and finish it off with reverb.
is there a different or better way of arranging these in a different order with different plugins or are these fine to work with. suggestions please on good pro tools plugins and order of arranging them. thanks you guys. well i use the perception 220 from AKG and its just connected to my mbox 2. got a reflection filter and room is acoustically treated.
Re: Vocal Chains
I say train your ears, and learn how it "should" sound. Presets and others suggestions will only get you so far. You have to learn how to recognize what the problem is with a sound or a mix, and then how to best fix it. Took me years to realize this.
Re: Vocal Chains
I'm a reverb whore.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh Mainboard: DFI Inc. INF P35-R BIOS : Phx Tech, LTD 6.00 PG 03/11/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus MP APIC : Y Tot Mem : 3.25GB DIMM DDR2 (WinXP) Chipset: Intel P35/G33/G31 Proc Front Side Bus Spd : 4x 266MHz Mem Bus Spd : 2x 399MHz (C:) : (250GB, SATA, 8MB Cache) (D:) : (250GB, SATA, 8MB Cache) |
Re: Vocal Chains
Re: Vocal Chains
Sign me up. My chain is MXL V89>Focusrite ISA-428>ART Pro VLA II(with NOS Mullard tube). Inserts are EQ III for hi-pass>BF76>EQ III for taming the "nasties">SMACK!(or softube CL1B)>Pultec EQ1QA. AUX send to reverb(either TL Space with EMT plate, or IK Classik reverb plate). Sometimes I send to another AUX with a touch of delay(followed by EQ to roll off from 2-3K on up).
Can you save FX chains? | Samscasa | macOS | 1 | 05-12-2012 08:06 PM |
Dialog processing chains | ajv205 | Post - Surround - Video | 5 | 05-15-2008 08:40 PM |
Plugin Chains | BabylonWillFall | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-10-2005 06:13 AM |
Side Chains! | Franchise | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 06-30-2004 11:50 AM |
Alice in Chains Vocals | music | Tips & Tricks | 1 | 02-09-2000 12:41 AM |
