Old 07-13-2010, 06:33 PM
Brandonx1 Brandonx1 is offline
Default Problem populating HD 4 accel + Process + Process
Hi All,
I'm having a problem building the mixer. I'm getting an error saying there is not enough DSP for the mixer. I have a whole process card empty. I've used up all but one chip on my only accel card. Everything else is full. I thought the mixer can use any DSP chips available in the system. This is an older PCIx HD system and 8.0.4. Anyone have a clue what is going one here?
Thanks,
Brandon
Old 07-14-2010, 03:48 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Default Re: Problem populating HD 4 accel + Process + Process
I don't know off hand if the mixer has to use an accel chip or not, but it may be the DSP assignment has got confused. Is your DSP cacheing off? Try turning that on and off and then reloading session
cheers
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 07-14-2010, 08:08 AM
cheers
Hi Mike,
Thanks for the help. Yes DSP cache is off. First thing I tried. I also tried quitting PT and opening the session again. Nada. Anything else to try?
Best,
Brandon
Old 07-14-2010, 09:35 AM
Craig F Craig F is offline
PCIx card and 8.0.4? what computer are you using?
what does Digi Test report? (I'm thinking bad TDM cable, hopefully not card)
Thank you,
Craig
Old 07-15-2010, 12:17 PM
quadraphonics quadraphonics is offline
Are you using an expansion chassis? If so, which one? There are a few (i think) expansion chassis that we no longer supported beyond 8.0.3
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 07-15-2010, 02:09 PM
bad jitter bad jitter is offline
If you are using the supported Magma chassis, there is very specific order the cards must be on chassis. Just guessing...
Old 07-15-2010, 04:40 PM
Hi All,
I am using an expansion chassis. It's the p7r646. I know I know, not supported. Actually it is. I'm using a PCIx windows computer which is supported with this config. Card order is correct. Core, then accel, then process, then process. Digitest shows all cards pass 100%. I can populate the last process card with TDM plug ins, just not the mixer. I can even have the playback engine on the last process card if I chose 6 DSP's and 192 voices. Also, ADC will populate the last process card. Just not the mixer. Odd problem I guess. Just looking for a rule I have overlooked regarding DSP management or the like.
Thanks for all the help.
Best
HTML code is On
Process Card Question... Accel vs non Accel gsilbers Pro Tools TDM Systems (Mac) 13 05-22-2013 01:51 PM
process to accel hd2 pie55 Pro Tools TDM Systems (Win) 3 03-09-2012 08:54 AM
hd process and accel process in same machine? blumediaprojekt Pro Tools TDM Systems (Mac) 1 02-01-2006 07:51 PM
Need more DSP. Accel or used Process? KenSluiter Pro Tools TDM Systems (Mac) 4 12-21-2004 01:55 PM
HD Process to Accel Exchange vs. Mix to Accel Exch Armando Pro Tools TDM Systems (Mac) 3 05-20-2004 04:18 PM
