001 LE 5.1 incoming ADAT signal too hot
Does anybody know why all 8 incoming ADAT channels (coming from a Presonus digimax) are so hot? The singnals into the digimax are not hot, and the pads and gains on the digimax are all down. I saw in Hardware that I can lower the input gains on the six analog channels on my 001 box, but didn't see how to do this to the ADAT channels. anybody know what's going on?
Thx Isaac |
Re: 001 LE 5.1 incoming ADAT signal too hot
Isaac ,
Welcome to the forum.. There are very few pieces of equipment, which allows you to control digital IO levels. The 001 isn't one of them. So..in your situation try lowering the level going into the Digimax. ( line level I'd assume ) good luck,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Thanks - I can't believe that the 001 and/or digimax are so sensitive - so I can't use a clip-on mic to record a snare, or even send a vocal signal?! crazy. is there a light-pipe "pad" that can go between the digimax and 001 to lower the signal strengths?
Isaac |
The cure would be in-line mic attenuator pads. They'll always come in handy,,so start there. like this > ; or this >> I don't own the Digimax ( usually rent them for live gigs)..but would think that the built in pad and the gain control can handle most mic outputs.. good luck,
funny thing is, the signals coming into the digimax are barely tripping into the yellow. no peaking at all. I thought a sample-rate sync problem might be to blame.
OR, it could be the way I am getting signal to the digimax: i am recording live, so mics come into the house mixer, and I send clean signal to the digimax from the inset jacks (TRS cables plugged half-way in) on the back of the mixer, so that the signal is split off to the digiamx there, and also continues thru the house mixer. Thanks for your help - I'll keep searching. |
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
What is the house mixer ? See if you have a pre-fader selectable direct out. If so the mixer's preamp gain should be adjusted for proper level. The house guy than can raise the channel fader or bus send, etc..to get his/her desired level. Ideally though, you'll need a transformer isolated mic splitter before the mixer/Digimax. BTW..it is better to be clear in the first post as to how everything is hooked up. so we don't waste time going around to find solutions.. good luck,
excellent. Thank you.
Isaac |
Digi002 - RCA-S/PDIF not showing incoming signal | Ormond | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-13-2010 10:11 AM |
No Signal for ADAT Inputs | fooloof | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-14-2009 10:01 AM |
No signal via ADAT Optical | almon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-02-2008 11:26 AM |
Incoming signal even when protools is off | MiguelOne604 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-14-2006 03:41 PM |
Using an Aux Input to record plug ins on incoming signal...Discuss.. | Jules | Tips & Tricks | 8 | 03-19-2001 04:38 AM |
