Old 12-04-2022, 08:49 PM
DigitalDragon DigitalDragon is offline
Default static...
i hearing static on certain tracks , some tracks are fine but some of them have static. i dont know what to do. i hope its a quick fix. thanks
Old 12-05-2022, 07:22 AM
Default Re: static...
Could you give less info?!?! Complete system specs are needed before anyone can offer much help. Then, is this a new problem or is it always like this? How were the static tracks recorded? Was everything recorded the same and on your system(or imported from another)?
Old 12-05-2022, 07:46 AM
junkgear's Avatar
junkgear junkgear is offline
Like albee said, the more information we have about your system and how you are recording, the better we can help you.
At least provide your system details, Pro Tools version and audio interface.
Then tell us a bit about what you are doing. Are these all audio tracks, any imported audio, any troubleshooting steps you have already taken.
Will
System Details
Old 12-05-2022, 09:59 AM
sorry i understand.
i'm on hp laptop windows pro
pro tools 12 studio update....
running off of yamaha headphones.
no audio interface attached.
Old 12-05-2022, 01:20 PM
using kontakt
instrument track
Old 12-09-2022, 09:13 PM
anyone out there that knows this error. please help. thanks
Old 12-10-2022, 08:43 AM
What is Pro Tools using as its "audio engine"? If its ASIO4ALL, then I suggest its time to get a real interface(Focusrite Solo Gen 3 is a bargain and may be all you need). If its not ASIO4ALL, it might be worth giving that a try(its free). Just know that its a "last ditch" solution and not the best(a real interface is the way to go if you plan on doing much recording)
Old 12-10-2022, 01:21 PM
sometimes i get cpu overload error. i forgot to take picture of it....heres the other readout. i have audio interface behringer uphoria. but only use it to record.
Old 12-11-2022, 06:16 AM
is it better to record with 256 or 512 or 1024...
Old 12-11-2022, 01:12 PM
This setting has no effect on recording. It has a huge effect on how much latency you hear WHILE recording. Lower numbers(like 64 or 128) will usually have low enough latency that you will not notice. Higher numbers(512, 1024) will have too much latency(delay) and that will make it tough to stay in time with a click track or previously recorded instruments. If 256 is the lowest buffer you can select, then its really time for a real interface, because 256 is really too much latency for recording. If all you do is mix(not record), then choose 1024 as that allows the computer the most time to do its processing(if you are not recording, then overall latency is not an issue).
Static "Playback" with Protools and Static "Playback" with windows files 39lashesmedia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-20-2011 05:57 AM
Static!! Omg joeyd38 Pro Tools SE and Essential (Win) 0 03-26-2011 01:41 PM
Mp3 / Static ice0-5 Tips & Tricks 1 03-15-2011 10:59 PM
How to get rid of static madoa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-07-2007 04:34 PM
NO, static please go away Reckah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-04-2005 01:04 AM
