Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 05-30-2020, 01:27 PM
Carl Lie Carl Lie is offline
Default Re: PT 2020 Whats Up With The Crazy CPU Spikes?
Originally Posted by GroovnD313 View Post
So after re-installing 2020.3 again and double checking the buffer I can report it's not that. And it did stay at 1024 after installing. De-activating every plugin in the session and re-activating them one by one does not show any strange jumps and just leads me to believe that it simply just does not run as efficient as 2019.6
I'm sorry I didn't help. Hopefully you can still enjoy your system.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 06-01-2020, 10:22 PM
Rectifried Rectifried is offline
still does this.. jumps to 100% and flashes
Have to quit PT and try again... yes might be a plugin but .. really?
im 12 core Tcan 64G ram.. Can I spoon feed this covidian resthome SW DAW any more applesauce?
really.. were running at 30% then FLASH spikes flashing red 100% cpu and I quit etc..
Ozone8? not always using it.. and NO Im not taking it out of the folder etc..
I use it .. it works
but PT is so so so cpu finniky.. cmon
knife edge to do the most simple things really ..
Hal Cragin On the DUC Since The Year 2000 AD
Ventura ,PT 2022.10, MacbookPro 13"[2020] M1 16G, Antelope Orion 32+ Gen3..SSL Sigma summing, SMART Comp C1LA, CharterOak EQP-1 Oceanway Audio HR4S monitors . SSL X-Rack w XR618 compressors, dbx 160x [2]
Old 06-02-2020, 08:38 AM
SBP SBP is offline
Can you raise a support case. And send then session with example?
Old 06-02-2020, 08:51 AM
Did it once or twice .. hrs of nothing I haven’t already done
Then the “ how’d we do ?!? Rate us! ” Emails for the following weeks
Old 06-04-2020, 12:48 AM
bluskiff bluskiff is offline
getting cpu alerts all the time Mac Pro 5,1 6 core 2012 3.33 Mojave protools 2020.5. Even on session with usage meter running around 4%. 32 gig ram ssd only half full.
I have been trying everything. using protools native ultimate uad . I have even started removing plugins out of the folder to see if one is acting up. Starting to wonder if its to do with older processor? new processors AVX just wonder if its time for new computer? I does stop when I run buffer at 1024 but If I try to record the monitor latency is just stupid.
  #16
Old 06-04-2020, 01:28 AM
But you have *not* been trying everything if you have just started removing plugins. And why worry about esoteric stuff before you try the basics?
*Always* suspect plugins. Don't fart around one at a time. Start by moving them all out of the plugin folder, trash prefs and restart Pro Tools... the default plugins get put back automagically. And does that now work sanely? If so start putting back third party plugins in big batches and see if you can find the problem one(s).
CPU meters are just not helpful (if it was always pegged when it was not supposed to be then that's more intersting). Plugin induced CPU errors at low CPU meter values happen all the time, just does not help. Disk % full is also irrelevant.
Nobody here knows what the cause of your problems is, if it's a plugin or not, but this plugin testing should be automatic for you to try, and if after doing that and other standard troubleshooting... then post here with a detailed list of what you have tried. And all what changed when this started. make sure that includes testing with a new clean empty session. And trashing prefs between the major things your try. And if nothing else works, then test from a newly created admin user account, repeating things already tested.
  #17
Old 08-29-2021, 07:50 PM
npatro22 npatro22 is offline
May I resurrect this post and ask if you ever found a solution? I just installed 2020.12 Ultimate HDX with HD i/o on a MP 5,1 running Mojave. CPU spikes the same, playback is impossible. RX 580, 64GB ram. When I change my audio interface to black magic deck link pci card it runs fine. I suspect it is something with HDX and the gfx card. After digging into Avids site I saw this, saying RX560 the only compatible metal capable gfx card. That’s seems too horrible to be true. I’m at a lost. High Sierra PT12 ran fine. Plan to uninstall everything and test 2019 I guess, but 2020 features are my preferred upgrade path. May need to drop some $ on a rx560 for due diligence.
  #18
Old 08-30-2021, 11:02 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Power draw with the RX580 (1-8pin) Alt HDX power?
560 (1-6pin) HDX gfx power (1-4pin)
Maybe Slot order as well.
Export video is crazy slow on 2020/Mojave melodydetective Pro Tools 2020 1 05-21-2020 11:13 AM
Pro tools 2020.3 Crazy Cpu and Ram % JeroRomero Pro Tools 2020 34 05-15-2020 08:03 PM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
CPU spikes like crazy tobbelito Pro Tools 2018 3 10-17-2018 03:42 AM
