Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 05-23-2020, 04:29 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Hardware inserts Pro Tools
Only annoyance is when you do surround sessions you need to double-check your routings as you would normally have front stereo on outputs 1-2 but if you have set up for hardware inserts you would likely have rear stereo on outputs 1-2 instead
Janne
Old 05-24-2020, 02:27 AM
Becharax's Avatar
Becharax Becharax is offline
Yes no problem ... just need to dig in the cables because they are stuck behind my desk not too handy and fix the output I/O so that 1/2 isn't main monitors anymore ...
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840/Slate VMS
https://open.spotify.com/artist/7KfV..._branch=1&nd=1
Old 01-19-2021, 10:45 AM
Decano Decano is offline
Originally Posted by JFreak View Post
PT Hardware Insert requires matching I/O numbers. Need to be on the same interface and same number. As in Output1 to Input1
I find this difficult to believe because it is not very flexible. In Logic it can be perfectly as another user said.
For example: I am a user without patchbay and all my hardware is connected to my RME 802. I use few processes but regularly.
For example, the famous UA 6176 has 2 options:
- input UA 610 (out 5 on my RME)
- output UA 610 (in 5 on my RME)
- input UA 1176 (out 6 on my RME)
- output UA 1176 (in 6 on my RME)
I understand that I can match in / out of both. But what if I want to do the following?
- Input UA 610
- Output UA 1176
So in Pro Tools I can't do out 5 / in 6. Really? In Logic I/O plugin you can choose the output and the input of the Insert. Is there any way of doing this in Pro Tools?
Any opinion about that? Thanks!
Old 01-19-2021, 10:59 AM
JFreak's Avatar
Yes, that is how it is. Need to be matching i/o for Hardware Inserts. That is one of the DSP mixer rules that Avid has chosen to match in Native to avoid confusion.
Janne
Old 01-19-2021, 11:15 AM
Thanks!
  #16
Old 01-19-2021, 05:17 PM
If you(the OP) are going to dig into cabling, then you might leave 1 thru 4(or 1 thru 6 if you are planning for 5.1) as your main outs and setup higher-numbered IO for hardware inserts
Pro Tools 12 and RME TotalMix - using hardware inserts send/return DAT11 macOS 5 04-27-2017 03:41 AM
Pro tools hardware inserts with behringer X32 ssadrummer Windows 1 10-31-2016 03:04 PM
Hardware insert 1&2 cutting off other hardware inserts on aux tracks Led Windows 4 12-09-2013 09:19 AM
Pro Tools Hardware Inserts 9 with ProjectMix aqueronte macOS 3 04-12-2012 08:31 PM
Configuring Hardware Inserts in Pro Tools 6.1.1 htp_exe_producer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-12-2004 06:58 AM
