Old 05-07-2020, 03:12 PM
Bill_Kelley Bill_Kelley is offline
Default Using HDX interface to record to Ableton
Before I got Pro Tools Ultimate software I could open Ableton and use the Avid HD I/O to record audio in Ableton. Now, when I run Ableton (Pro Tools is not running), the HD I/O doesn't see the signal coming in from the preAmp. Any suggestions (besides abandoning PT or Ableton)?
Presonus PreAmps lightpipe into
Avid HD I/O
using Mac Pro (2013)
OS 10.14.6 (Mojave)
Software: Pro Tools Ultimate
Ableton Live 10 Suite
Thanks in advance (I hope it's good news... i.e. a simple fix)
Music, it's a mystery...
Old 05-07-2020, 06:58 PM
LukeHoward LukeHoward is offline
Default Re: Using HDX interface to record to Ableton
There appears to be a specific issue between Live and the HDX CoreAudio driver. It's been discussed here a few times already, e.g. here. I have an open support case with Ableton.
https://lukehoward.com/
Old 05-13-2020, 08:49 AM
DetroitT's Avatar
DetroitT DetroitT is offline
please clarify.
Your HD I/O was only connected via lightpipe.
No digilink (HDnative card or HDX card)
No HD driver installed
Is this correct?
Old 05-13-2020, 11:37 AM
HD I/O connected to Mac Pro via HDX card.
PreAmp connected to HD I/O via light pipe.
Signal meters on HD I/O light up when PT is running but show no signal when I run Ableton.
Old 05-13-2020, 03:53 PM
Ableton are aware of a specific issue with the interaction of the Avid HD CoreAudio drivers and Ableton Live. There is no timeline for fixing it at this stage unfortunately.
Old 11-30-2020, 04:11 PM
raw raw is offline
Hi Luke, was there a resolution to this? I want to install Live 10 on my Mac (PT Ultimate 2020.3.0, HDX, 2 x HD I/O) but it sounds like the Avid CoreAudio driver won't work. Thanks.
D Show Profile interface with Ableton midi. konstantinos General Discussion 0 03-04-2015 02:44 PM
2 Part Question: MacBook and Ableton Live Interface Mista Mystic macOS 4 04-08-2013 11:29 AM
easiest way to record audio from Ableton Live? eric22rr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-02-2007 08:05 AM
Can I record Ableton's Beats rOckstar86 Pro Tools M-Powered (Win) 7 09-13-2006 10:30 AM
Record ableton in protools ITZIK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-02-2004 01:01 PM
