Old 09-06-2019, 11:33 AM
peterle peterle is offline
Default 2019.6 Bug? Quicktime bounce w/o sound when online bounce
... i get no sound in the "Bounce to Quicktime" exported file
when "offline" is NOT checked......
no big deal , after i found it out , but ...
shouldnt it work online too?
foley artist , soundeditor
Old 09-06-2019, 11:43 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: 2019.6 Bug? Quicktime bounce w/o sound when online bounce
If everything else remains equal except online/offline then it sure enough sounds strange
Janne
Old 09-06-2019, 11:58 AM
...same settings except "offline"
several attempts
Old 09-06-2019, 01:15 PM
According to your profile you are running HDX so there is always a suspicion you have damaged plugins when this happens. Offline bounce runs all the plugins as AAX-Native. Realtime bounce will run as AAX-DSP. You can remove all .aaxplugin files from the plugin folder and let pro tools put back the standard ones and just see if that works (many of your plugins will of course not be running--but does that even work?).
Have you tried trashing prefs? Does this only happen with one session? ... lots of usual troubleshooting questions.
Old 09-06-2019, 04:40 PM
BScout BScout is offline
Online bounce works just fine here (same as offline -- mix of AAX and AAX-DSP plugins)
I'd check any plugins you might be using that are AAX-DSP.
Do you hear anything when doing the online bounce (you should)?
Old 09-07-2019, 12:11 AM
...onliest plugin here involved was avid pro limiter (DSP) ,
i may try trash preferences today , yes its on hdx , mojave.
Old 09-07-2019, 12:27 AM
.....found the culprit:
originally the session was created with PT 5.13 Mix (way old)
later converted with PT10 and now opened with current PT,
the session had few , of course now inactiv because they dont exist anymore, EQ II plugins in the session on several tracks as insert.
After removing them even an online bounce works now.
BTW i was always talking about QUICKTIME bounce with Video file.
seems , at least here , not existing , inactiv , plugins can cause
online quicktime bounce errors......
exotic circumstances i have to admit , but still a tiny little bug in my opinion.
regards
Much slower offline bounce in 2019 vs 2018? Brettster Pro Tools 2019 15 09-10-2019 03:17 PM
PT 12 offline vs online bounce AntonFAudioDesign Pro Tools 12 12 04-05-2015 04:51 PM
CPU errors during online bounce Dynamixaled Pro Tools 11 5 02-08-2015 12:05 PM
No Sound with QuickTime Bounce CrazySloth macOS 3 01-15-2014 06:18 AM
Bounce to Quicktime- could not finish bounce ? gw sound Pro Tools TDM Systems (Mac) 5 09-09-2007 09:43 PM
