Old 08-28-2011, 09:32 PM
papitopinillo papitopinillo is offline
Default How to add more inserts into a track?
There's anyway to add more inserts into a track i run out need more oops btw im on a mastering process,,
thanks a lot
Old 08-28-2011, 09:44 PM
Top Jimmy's Avatar
Default Re: How to add more inserts into a track?
If 10 inserts aren't enough, you can route the output of the track through an aux track and get 10 more inserts.
If you only have 5 inserts showing, go to Views and reveal the other 5.
James Cadwallader
Old 08-28-2011, 10:55 PM
JFreak's Avatar
JFreak JFreak is online now
If 10 inserts are not enough, you will probably have to rethink about what it really is that you want to achieve? Or maybe the mix isn't ready to be mastered yet? Don't polish a turd, man...
Janne
Old 08-28-2011, 11:02 PM
Thanks a lot for the idea just wonder there's any problem with de delays or re verb or others vst,delay comp, etc ...with that... I mean does not get mess up !
Thanks again for the support!
Old 08-29-2011, 08:35 AM
i think now 10 insert its not enough for mastering at all..
Old 08-29-2011, 10:34 AM
JFreak's Avatar
Give me well mixed song and I'll master it with one insert -- channel strip that has eq and compressor and a bypass switch
Janne
Old 08-29-2011, 12:41 PM
daeron80 daeron80 is offline
Just keep chaining those Aux tracks to each other, and stick a master on the bus while you're at it. 10 inserts per Aux + 10 inserts per bus Master. 1 audio track, 160 Aux tracks each with its master, then a master on the output, right? That's 1620 inserts. Now put Ozone4 in each slot.
[Update] Totally wrong about that, sorry. First, forgot to add the master buss inserts. Then forgot we only (!) have 256 busses. 128 pairs of busses. So you can only (!) use 128 Aux tracks, each with a master on its bus, for a total of 128*2 sets of 10 inserts each. That 2560 inserts. Plus the Audio track, plus the final output master track adding another 10 each. 2580 inserts. Oh, the fun we could have.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 08-30-2011, 08:03 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 08-30-2011, 08:28 AM
ondruspat ondruspat is offline
I have yet to use all ten slots on ANYTHING!!!
I guess I must be doing something wrong!!!
"Sometimes having limits keeps you sane"- Albee1952
Old 08-30-2011, 08:43 AM
I think we ALL are
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
[IMG] code is Off
How do I copy inserts to another track gavriil1 Pro Tools 10 8 11-21-2012 01:15 PM
Track Fuzz wih no Inserts AlexDC Pro Tools M-Powered (Mac) 0 04-28-2010 07:41 AM
Inserts are "post" track, right? tlester Pro Tools TDM Systems (Mac) 2 02-07-2007 09:30 AM
Track Transfer with inserts midimac Pro Tools TDM Systems (Mac) 5 05-01-2000 06:09 PM
switch order of inserts in a track Viper Tips & Tricks 6 02-25-2000 08:57 AM
