Drive not seen in 2019.12, seen with 2019.6
I have one drive that 2019.12 won't see or mount yet if I use an older version of protools 2019.6 it sees the drive just fine.
Drive in question mounts just fine on the mac desktop and is 100% accessible. I've checked the drive with disk warrior and it's perfectly optimized accoring to DW. I've been in contact with AVID tech support ( I have an active support plane and don't want to upgrade just yet!) And avid aren't of any help! I can post all the solutions AVID have suggested but in the end none work! So what would explain 2019.6 seeing the missing drive without a single glitch yet 2019.12 wont even see it ?! I'm on Mojave Macpro late 2013 3.5 Ghz 64 gigs ram Also note I have a 2nd machine macmini 2018 same OS. and the drive is seen without an issue in both 2019.12 and 2019.6 I'm using an external bay drive enclosure via a Lacie Esata hub. The bay drive also has USB 3 on it and have tried connecting via that and same issue. Very odd. Also this started happening in the last month. Wasn't an issue before. Sent from my SM-N950W using Tapatalk
Cory Rizos, CAS Re-recording Mixer/Sound Designer Montreal, Quebec http://www.imdb.com/name/nm0007185/ coryrizos.com |
HDX Ultimate - 2019.10 7 2019.12 - video export issues | anguswoodhead | Post - Surround - Video | 2 | 03-09-2020 02:33 AM |
Pro Tools 2019.12 Ultimate Crashes 2019 Mac Pro | rmccam | Pro Tools 2019 | 11 | 02-28-2020 03:59 AM |
Workspace Borked 2019.10 and 2019.12 | KMcK | Pro Tools 2019 | 0 | 01-17-2020 02:09 PM |
2019 iMac vs 2019 Mac Pro | Peterjk | Pro Tools HDX & HD Native Systems (Mac) | 7 | 01-14-2020 12:23 AM |
Install pro tools 2019.10 over 2019.6? | Clarkston Guy | Pro Tools 2019 | 6 | 11-01-2019 08:12 AM |
