Old 01-16-2019, 01:48 PM
danieleither danieleither is offline
Default Upgrade PT10 HD3 to PT Ultimate HDX
I’m just about ready to upgrade from a PT10 HD3 system to PT Ultimate with HDX card (also an upgraded Mac Pro). I’m curious as to whether I’ll be able to open my PT10 sessions on the new system, and how the plugins and mix will translate etc?
I use mostly the stock plugins (DSP) where possible and a handful of native plugins (Waves and soundtoys).
Old 01-17-2019, 09:20 AM
WernerF WernerF is offline
Default Re: Upgrade PT10 HD3 to PT Ultimate HDX
The mix translates just fine except for the plugins that are not updated or didn’t follow the path to HDX. It just depends on what plugins you are using. The main drawback is that many manufacturers have not gone to DSP and created Native versions of their plugins. If this doesn’t bother you then you are good. Just go ahead and upgrade whatever plugins that you need to upgrade. Oh and by the way, the Soudtoys presets do not transfer to the Native versions of the plugins. You get an error message stating that the preset was created by an earlier version of the plugin so, unfortunately, those do not translate unless of course you are already using the latest Native version. I, for one, still use the TDM versions when using the P Tools 10, cards maxed out in a chassis system, which is what I still use most of the time anway to make records and mix as I go. I am feeling more and more left behind though and will probably fully transition to the HDX system soon so that I can take advantage of the newer OS and plugin updates.
Old 01-18-2019, 02:24 PM
As long as audio in the old sessions is in WAVE format and not SD II, things should open fine. MOST plugins will also be okay, except for the few that got nixed, or big re-writes(now its a single delay plugin instead of Short, Long, Extra-long......).
HTML code is On
Pro Tools Ultimate 2018(HD) perpetual license w/Support & Upgrade Plan and more Evermore Buy & Sell 0 12-07-2018 11:33 AM
Upgrade to 2018 ultimate audio drop out ubxf Pro Tools 2018 6 08-15-2018 06:30 AM
Komplete 9 Ultimate Upgrade or an Alternative PatriotsBiker Virtual Instruments 4 03-29-2013 03:42 PM
How to reinstall PT10 if PT10.3.2 upgrade failed? Martin11 Windows 12 12-09-2012 03:16 PM
Upgrade Vista Premium to Ultimate -- Can do? msgood 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-05-2009 02:16 PM
