Old 01-06-2019, 05:34 PM
Justin1524 Justin1524 is offline
Default USB AAX Plugin, does it exist?
Here's an idea for a plugin I'm not sure exists. I want to use PT's HD Native driver why? Because I do! I have a Boss Katana 50 guitar amp that I'm loving which has no analog stereo output but I believe does have a stereo out via the Boss Katana USB Sound Driver. Why not have an AAX plugin that can route audio from any USB driver into Pro Tools on an insert? Maybe this exists now and I just haven't found it. The closest thing I know of is Source-Nexus which allows you to take audio from your Mac's system sounds (youtube etc.) and, using an AAX plugin, listen on a Pro Tools track while using the HD Native driver which is incredibly useful. Avid should take notes because I'm sure folks would love it if an input selection in Pro Tools covered USB drivers.
Justin (Proud Pro Tools Ultimate PERPETUAL license owner)
Admin
www.elevenrackpresets.com
Studio: 2021 Mac Studio Ultra M1 20 Core CPU, 48 Core GPU, 64GB Ram, 4TB SSD boot | Pro Tools Ultimate 2022.12 | PreSonus Quantum 4848 interface| MOTU 112D interface | Digi PRE, FR OctoPre MKII, Mackie Onyx 800R, Panasonic WZ-AD96M (x2) and DA7, Eleven Rack, Apogee Big Ben, Mercury, Rode K2, Slate VMS ML-1 (x2). Laptop: Dell Inspiron 5559, i7-6500U 2.6Ghz, 16 GB RAM, 15.6" 1920x1080 1TB SSD
Old 01-06-2019, 09:54 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: USB AAX Plugin, does it exist?
How does a Guitar amp have a stereo output?
Obviously it’s not true stereo
Daniel
Old 01-07-2019, 05:54 AM
Why do you want the audio from the Katana to go into an insert? Why not a regular input on an audio or aux track? For that you'd use an aggregate device setup in OSX audio preferences.
Jack
QAPLA!
Old 01-07-2019, 06:59 AM
I don’t think I can combine the HD native driver with the Katana driver using PT aggregate IO because the native driver is PCIe not USB.
I’m guessing the Kanata has stereo effects such as reverb. FWIW the mono line out which disables the speaker when plugged in isn’t too shabby. Probably the best way to record the Katana though would be to put a mic or two on the speaker. Amazing value for money on this amp.
Admin
Old 01-07-2019, 07:42 AM
Doesn't matter what connection scheme is used for audio interfaces. Try and setup an aggregate interface scheme and see if it works.
Do you use your 11R as an interface alongside the HD Native pcie card? Same deal as using the Katana.
Jack
QAPLA!
Old 01-07-2019, 10:14 AM
YYR123's Avatar
Cool, makes sense now. I am unfamiliar with Boss amps in general
Been eying a Fender Tweed 5E3 DIY kit....looks like fun and could be an awesome Boutique style amp.
Daniel
Old 01-07-2019, 11:37 AM
Upon closer inspection the Katana 50 does have a single analog TRS stereo output jack so you get the built-stereo effects that way. Plugging into it doesn't turn off the speaker and using the Tone Studio software you can alter the speaker emulation characteristics. Not something I'd necessarily use but nice to know it's there. Would've been nice if you could just manually turn the speaker on the off with a switch but no biggie.
Admin
Old 01-07-2019, 01:03 PM
Must be talking about one of the StewMac kits.
Jack
QAPLA!
Old 01-07-2019, 01:04 PM
Get a load box and use that.
Have you tried the aggregate setup yet?
Jack
QAPLA!
Old 01-07-2019, 10:36 PM
YYR123's Avatar
Justin how much did you pay for the amp?
If you don’t mind me asking. Surfing Craigslist and I saw one for $200
Seems cheap -
That kit I want to put together is $200 just for the head
$100 for the transformers
$300 for the cabinet
Sure it’s one of a kind, and probably a different tone (and would last a lifetime) but if I could get a cheaper amp right now that would be cool too.
I have recently started hating PCB’s in amps since Fender won’t sell me a replacement for my 93 Blues Deluxe
Daniel
HTML code is On
Will exist a 004 flautista Pro Tools 10 1 01-12-2013 01:50 PM
Midi sequencer plugin for protools... does one exist? theaero Tips & Tricks 14 06-30-2012 08:37 AM
Can 7.x and 6.x co-exist? 3over3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-23-2005 08:20 AM
Time Adjuster plugin - does this exist? GenerationM Tips & Tricks 5 06-01-2005 03:47 PM
there exist?????? Cesarin Tips & Tricks 3 01-22-2003 01:33 AM
