re heat on 10
I have pro tools 10 and heat, when I first startup pro tools I can see heat in loaded but when I open a session it's no where to be found, can someone shed some light on this for me please?
JAMAICAN I IS 2008 2009 and 2010 Mac Pro 8 core with 64 GIG memory with 9 terabyte of hard drive space blue ray player HDX 1, 2 16X16 interfaces sync I/O. |
Re: re heat on 10
Mix Window > bottom right > should be an arrow icon : click on it to open up the heat section. Is it there ? active ?
Also : bottom left : the drop down menu for the mixer view properties : is heat flagged ? Chris
Chris Lambrechts Applications Specialist- Live Sound |
Also so it only works with HD and not native. If you are running HD Accel and still not showing, you need to make sure it's not in the unused plugin folder.
Mac/library/ app support/ digidesign/plugins (unused) |
Re: re heat on 10
I am wondering if it's not compatible OS 8 ?
Re: re heat on 10
Do I have to have an interface connected with HD 10 to make heat work??
Re: re heat on 10
Maybe an obvious question... But are you using PTHD? HEAT only runs on PTHD and only on TDM or HDX cards. HEAT will not run natively on a laptop.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Re: re heat on 10
As in the previous message, yes I am using 10 HD and I am not using a laptop
Re: re heat on 10
So you are running HD on an HD card of some sort? You do need to run through an interface.
Re: re heat on 10
I am not going through a card just from the computer
Re: re heat on 10
Thanks
Does comping to a Heat enabled track print the Heat? | joshdrucker | macOS | 0 | 03-12-2014 10:17 PM |
Heat? or Something Like it? | Numi | Pro Tools 9 | 24 | 06-11-2011 06:13 PM |
Something like Heat for LE? | DonaldM | Tips & Tricks | 15 | 02-04-2011 02:20 PM |
HEAT and PT 9 non-HD | chicken | Pro Tools 9 | 1 | 11-10-2010 06:43 AM |
Heat vs VCC | [email protected] | Pro Tools TDM Systems (Mac) | 24 | 11-01-2010 05:36 PM |
