Output/Input "None"
bandicam 2018-10-06 19-06-59-979.jpg bandicam 2018-10-13 20-23-55-747.jpg No sound at all. |
Re: Output/Input "None"
Hey Brother, first off Welcome to the Community
What interface are you running? You either need an interface or asio4all installed to simulate an interface to be able to use the onboard audio card. What computer (exact model and peripherals) ? What windows version? We need a lot more info to troubleshoot. Have you tried going into settings - i/o and there set every tab to default? Has this system worked before? Read this "sticky" post as it outlines a lot of what we need to help and has some great optimmization tips which needs to be done to your computer etc. http://duc.avid.com/showthread.php?t=300050 Try the default stuff and let us know what happens or doesn't happen.
"No output device selected in Studio Monitor Express, using Default Output"?? | Focuret | Pro Tools 10 | 4 | 01-11-2014 02:31 PM |
Channel I/O keeps loading old I/O and not "no input"/"no output" | Arve Gotfredsen | macOS | 4 | 02-12-2013 04:38 AM |
setting the "output to amps" outputs to "rig no cab" affected also the (xlr) outputs! | italianguitar | Eleven Rack | 15 | 03-20-2012 01:57 PM |
1/4" Balanced Output Jack to 1/4" unbalanced aux input heaphone amp | edgarbc1 | General Discussion | 4 | 12-13-2010 09:00 PM |
MTC input disabled when "Beat clock to port.." or "MTC to Port..." is enabled | OKden | Pro Tools TDM Systems (Mac) | 2 | 10-27-2001 03:24 AM |
