Won't Install on Mac OS 10.13 - Is There No End?!
I've just purchased ProTools on a monthly subscription, downloaded the DMG and tried to load. I'm running Mac OS 10.13, High Sierra. ProTools installer says :
Pro Tools cannot be installed because the following error(s) were found on your system: - An incompatible version of the OS was found. Pro Tools 10.3.10 requires Mac OS X version 10.7 or higher. I've lost at least two hours this morning in the studio dealing with one episode after another of either crap software or firmware that have version collisions, connectivity issues, etc, all resulting from manufacturer incompetence, and it's become a very costly, daily routine. So what is it this time, Avid? I'm running 10.13 on my Mac. Why isn't the installer seeing that? What array of hoops do I have to navigate my way through to defeat this nonsense? I've downloaded the Pro Tools 10.3.10 Installer (Mac) (2.33 GB) package. What else do I need to do to get it to install? Am I wearing the wrong color shirt? Should my system be facing north instead of west? Is it because I'm attempting to do this on a Thursday, or something I had for breakfast? I've bought your product. I need to install it. Last edited by Cayce; 08-23-2018 at 07:20 AM. |
Re: Won't Install on Mac OS 10.13 - Is There No End?!
If you’ve purchased a monthly subscription, it should be PT2018 not PT10.
PT2018 is the version that’s compatible with that OS and is the latest version. Sent from my iPhone using Tapatalk |
Thank you for your response, Sardi, but that not only doesn't solve the problem but only ads to PT's apparent incompetence. If I'm supposed to be using PT2018, why was I directed to a "My Products" page showing only PT10 for my system? Where is this PT2018?
That I can’t help you with unfortunately.
The only people that should have access to PT10 are people like myself that bought into a perpetual plan when PT10 was actually released. We have access to v10, v11, v12/v2018. AFAIK, monthly subscription plans should only have access to the current version which would be PT2018 and that would work with your Mac OS. I’d hit up support or search out a guy called Jeffro on this forum who will be able to solve your issue. Sent from my iPhone using Tapatalk |
That's ok... I found it. Thank you for pointing me in the right direction.
And...
What was the issue that conjured up so much disgust?
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
"Is there no end"....not to incompetence.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Install PTHD 8.1.1 udater on Win7x64 and says valid install not found 8.0.3 is there | rnygren | Pro Tools TDM Systems (Win) | 2 | 10-25-2014 10:58 PM |
Mountain Lion/PT Install/Ilok install problems | alex obradovic | macOS | 7 | 07-14-2013 06:19 PM |
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! | shamanrock | Windows | 13 | 12-27-2012 04:39 PM |
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions | b-pole | macOS | 2 | 08-31-2011 07:23 AM |
Can't install Pro Tools LE - Insert disc but no option to install | Paul McConnell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-22-2010 08:13 AM |
