Re: First Note in Measure Missing
Its been like this all the time I think. If you use copy/paste you have to make sure the first note is right....
Antelope Orion Studio 2017, UA 4-710, Presonus digimax FS, Sony DMX r100 |
I found a workaround for the second issue I mentioned, the "persistent/undeleteable" note. I was able to workaround this doing the following:
1. Delete the entire measure that the persistent note resides. 2. Either: 2a: Recopy the entire measure from a different section of the original track. > Maybe there's a different section from the original track that is "OK". 2b: Manually recreate the entire measure by manually creating each midi note. > Note: This may require putting the midi editor in "spot" mode as mentioned in my earlier post. Hope this helps. |
Such a pain in the arse to have to go back and manually draw back missing notes or figure out other clunky workarounds which slow your flow down.
Pearlman Church Microphone > Great River MP-2NV > Warm Audio WA-76 > Apogee Symphony MK II 8x8+8MP > PT2018 on 2018 Mac Mini with 32GB of RAM running Mojave. |
I have seen this issue again this week. For me it mostly happens when dragging a midi file to the timeline. The only way I could fix it was to set the grid to a whole measure and drag the midi file back one measure and then drag it back to its original spot. After that it worked as it should. It would be nice if they could really finally fix this issue.
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 Last edited by innesireinar; 10-21-2018 at 05:26 AM. |
Is there a way to display a Measure and Note grid down on the tracks? | gopher | Getting Started | 2 | 12-14-2013 11:47 AM |
First note missing on loops | Dstryr | MIDI | 0 | 04-27-2013 11:04 AM |
Midi 101 really missing? Set high note/low note on track's input | robinsonsdca | macOS | 4 | 11-10-2011 01:23 PM |
First midi note Hit always missing. | cwhite771 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-01-2003 12:20 AM |
Missing 1st Midi note ? | roaddog215 | Pro Tools TDM Systems (Mac) | 2 | 11-16-2000 05:03 AM |
