  #641
Old 10-20-2010, 09:51 AM
TOM@METRO's Avatar
Default Re: Pro Tools placing sound EARLY??
Originally Posted by JMS40 View Post
95 percent of all statistics are made up on the spot.
Less than 4% of all paid politicians will corroborate this.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #642
Old 06-02-2018, 12:04 AM
slashy's Avatar
slashy slashy is offline
I work on a Mac MI 2012, 128 Gb of ram.8X8X8 interface digidesign.
Pro Tools ultimate, and since 1 month , i have this problem.
The clip is placed sooner after recording.
Not easy to read the 65 pages of this thread, so is anybody find a solution to avoid this problem ?
I'm become mad since 1 month.
  #643
Old 06-02-2018, 02:52 AM
Zarabozo's Avatar
Zarabozo Zarabozo is offline
Originally Posted by slashy View Post
What version of ProTools are you using? They released this update that supposedly fixed the issue: http://duc.avid.com/showthread.php?t=284353
However, working with Pro Tools 10 or later is what you really want, as they have ADC (automatic delay compensation) and that alone makes everything a lot better.
HTH
The audio world is full of (mainly very expensive) placebos.
Windows 10 Pro 64 Bit
Pro Tools Ultimate (perpetual with active updates/support plan)
RME Fireface 802, Focusrite Clarett+ Octopre, Eleven Rack (ERXP)
Monitors: Yamaha MSP7 and Yamaha HS8S
Asus RoG Maximus Hero Z790 (in a 4U slidable rack mount! )
Intel Core i9-13900k 5.4 Ghz (16 cores / 32 threads)
128 GB RAM G.Skill DDR5 6000 MHz (4 modules 32GB each)
Boot disk: Samsung 980 Pro M.2 2TB
Media disks: 2 x Samsung 980 Pro M.2 2TB in RAID 0 for current work, 2 x Seagate Exos X20 20TB mirrored for archive and backup
Video: PNY/Nvidia RTX 3080 TI with a single 4K display Dell U3223QE 32''
  #644
Old 06-03-2018, 10:30 AM
slashy's Avatar
I work on Pro Tools ultimate but the problem is new since i update from 11 to ultimate !
Do you think there is a bug ?
Why ma i the only one ? i search on different forum, but everybody is astonished to my problem.
Have you resolve the problem, and how ?
Thank you in advance.
  #645
Old 08-20-2018, 06:55 AM
Jeezer Jeezer is offline
I have this on HD older version, if your audio interface isn't an avid one or one that mimics its (high) latency then audio often comes back 'early' when bouncing/commiting through hardware.
Use a time delay plug to ADD delay to the sending/committing track in the slot before the HW I/O insert, 23samples for example. The resulting capture is 100% in sync once yo'uve found your initial sample offset.
Using PT's own offsets either in HW dialog box or at the bottom of the mixer channels won't work as well (if at all) the user offets on the mixer is a band aid after he damage is done, it shifts it in synch audio wise (not visually) and you'll be missing X samples off the front of the committed file.
So..
[time delay plug] (I use eventides precision time delay)
[MY Hardware i/o]
then commit
then disable both the above if you want the track to run back in sync with everything again.
Pro tools placing Samples Early. the opposite of latency. thecoaster macOS 11 06-30-2013 02:54 PM
pro tools is recording early? Applebase 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-21-2010 07:44 PM
Early Film Sound Pioneer, George Groves minister Post - Surround - Video 4 05-22-2009 01:08 AM
Early Beatles Sound AmazingOne Pro Tools TDM Systems (Mac) 47 02-10-2008 02:49 AM
film print sound 2 frames early minister Post - Surround - Video 8 04-13-2005 09:37 AM
