Old 08-14-2010, 12:30 AM
Michael Carpenter Michael Carpenter is offline
Default Re: ProTools placing sound EARLY??
for the record.. i've been suspicious of this for a few weeks, but haven't had a chance to check it. Plus, i thought there was no way it could possibly be happening, so assuming i was just playing out of time!!
MC
Old 08-14-2010, 03:08 AM
No... not just a visual thing. Definitely hearing...
Old 08-14-2010, 09:07 AM
nerhal nerhal is offline
yeah I dont use low latency monitoring anymore. it doesnt work like it did before for me plus I can run it all at 64 so its ok for now. but if pro tools cant record a track in the time it was recorded then there is a huge issue here. I mean come on.
AMD Phenom(tm) II X4 955 Processor 3.21GHz
Gigabyte GA-790XTA-UD4
Total Memory : 4GB DIMM DDR3
Memory Bus Speed : 2x 670MHz (1.34GHz)
western digital black (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (C:)
western digital black (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (D:)
Memorex DVD+-RAM 550L v1 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:)
Windows 7 Ultimate 6.01.7600 x64
gateway 24inch hdmi dvi HD monitor
pro tools LE 8.0.4
Old 08-14-2010, 04:40 PM
No.. i think you've misunderstood... Low Latency Monitoring is the ONLY way it seems to be working correctly. In 64 buffer setting, it is placing the recorded audio EARLY... ahead of the beat..
An easy way to test your system is to play something.. anything really.. exactly in time with the click track. Then play back the recorded audio and see if it's still exactly in time.
MC
Old 08-14-2010, 04:48 PM
no I understood. I just don't like the low latency monitoring because the volume drops. it doesn't feel right to me anymore. I have recorded with the 64 buffer and it works fine most of the time. the thing is that this happens off and on. so its concerning to me to know why that is. I need an explanation from digi and a fix if there is or will be one.
pro tools LE 8.0.4
  #16
Old 08-14-2010, 07:49 PM
thisistruth thisistruth is offline
I agree with you, just noticed this myself. I have the following setup:
Win7 64bit
AMD Phenom II 1090T 6 core 3.2Ghz
ASUS EVO/USB 3.0 MB
8 gig OCZ Gold DDR3 1333 ram
2 SATA 500 GB hd's
I have tried everything to remedy this, low latency monitoring, 64 buffer size....can't get it to properly place the audio. Extremely annoying....I hope I didn't spend all this money to get a marginal-sub par DAW.....
  #17
Old 08-14-2010, 08:03 PM
I guess thats what happens when you have many many customers whining and begging for the newer compatible version of pro tools for win 7. they miss some glitches. I feel like I just got a new x box 360 game that was rushed.
pro tools LE 8.0.4
  #18
Old 08-14-2010, 08:42 PM
Man, I don't know what it is now but I've been messing with it for the last hour and now it seems like the whole system is going crazy. All my meters started responding super slowly, like way after you hear the sound, so I tried turning the buffer size back up...nothing. So I restarted and got the error that my 003 hardware is not compatible with PT. So after about 20 errors I finally got PT closed and rebooted. I got it back up and now it feels like I'm recording on Sonar 5 again on my old system.....slow and old. I supposed this is a good way to get us to invest in PT HD....if LE is any indication on how HD runs then I would never upgrade....I used a 001 in school with PT 7 and it worked awesome compared to this. Don't know what to do.....long time PT fan
  #19
Old 08-14-2010, 08:59 PM
mykhal c's Avatar
mykhal c mykhal c is offline
fellas, i hate to say this but you cats 'might' be runnin' into some FSB issues with the AMD setups. i hope not but that's the feelin' i'm gettin you guys are the pioneers for the new AMD rigs like others did the i7/X58 rigs. so your pain might be uncoverin' conflicts with PTLE and the new AMD procs and the mobos.
are these probs unique to 8.0.4 tho? or with any version of PTLE?
also to the OP...i really believe your situation is a result of the cross talk between the 2 cpus via the QPI resultin' in the latency you are seein'/hearin'. that's why i asked if this was your 1st session on your rig. i have yet to see a fully functional dual socket Xeon build that works here on the DUC. hopefully you'll be the first tho
so again, my questions are does this also happen on 8.0.3? and what happens if you record at a larger buffer?
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
  #20
Old 08-14-2010, 09:09 PM
I'm running a dual boot with an XP and W7 install on a 2 year old non AMD setup. No probs with the XP install.. 8.0.1...
Pro tools placing Samples Early. the opposite of latency. thecoaster macOS 11 06-30-2013 02:54 PM
pro tools is recording early? Applebase 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-21-2010 07:44 PM
Early Film Sound Pioneer, George Groves minister Post - Surround - Video 4 05-22-2009 01:08 AM
Early Beatles Sound AmazingOne Pro Tools TDM Systems (Mac) 47 02-10-2008 02:49 AM
film print sound 2 frames early minister Post - Surround - Video 8 04-13-2005 09:37 AM
