Old 10-20-2012, 10:19 AM
David Hardie David Hardie is offline
Default Prime for Playback/Record keyboard shortcut problem
I recently updated to PT10.3
The keyboard shortcut to prime for Record or Playback works OK to prime the Transport, but when actioning the Spacebar to record or playback the primed state is cancelled and nothing happens.
If the Transport is primed with the keyboard and then clicked with the cursor to run, it runs fine!
If the Transport is primed with the cursor and then actioned to run with the Spacebar, the primed state is cancelled and nothing happens.
The cmd-spacebar shortcut to Record works fine.
Have I done something blindingly obvious and stupid?
i7 Mini, 002R, OSX10.7.4, PT10
Old 10-21-2012, 05:47 AM
Default Re: Prime for Playback/Record keyboard shortcut problem
I did a clean uninstall of PT10.3, then made a fresh install of PT10.0.1 and the 002 drivers. The keyboard shortcut to prime the Transport for recording, ctrl+cmd+space, worked as it should; once primed in "record pause", pressing the spacebar put the Transport running in Record.
I did a clean uninstall of PT10.0.1 and made a fresh install of PT10.2 and the 002 drivers. The k/b shortcut worked fine.
After a clean uninstall of PT10.2 and fresh install of PT10.3.28 the symptoms I described in my original post have returned.
Has anybody else had this problem? Does this k/b shortcut work for you in PT10.3?
Record Enable/ Arm Track Keyboard Shortcut? bdilla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 08-17-2015 07:52 PM
Record - Keyboard shortcut? spires 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-21-2010 12:12 PM
keyboard shortcut "F12" record, stopped ??? dobryden2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-14-2007 01:21 PM
Keyboard shortcut for audio track record arm? smasyd Pro Tools TDM Systems (Win) 0 04-02-2006 06:57 PM
record-enable track keyboard shortcut redcootie Pro Tools TDM Systems (Mac) 1 12-21-2005 11:02 PM
