Plugins on a mixdown track
Hi All,
Q about mixing down w/ plugins. I want to mix down audio and aux tracks to a stereo audio track. I would like to have Comp/Limiter on the final mix. I'm guessing I should put the comp/limiter on the Master Fader track because I have low latency turned on... If I put it on the stereo audio track that is designated for the mix down, the plugin becomes inactive. If I turn Low Latency monitoring off, the signal from my ext sequencer is not synched up with the audio. So, by placing plugins on the Master Fader, will that send the 'effected' signal to the final mix down track? Thanks!
5K Retina 27" (2020) iMac OS 13.6.5 Ventura 3.3 GHz 6-Core intel Core i5 AMD Radeon Pro 5300 4 GB 64 GB 2667 MHz DDR 4 Internal 2TiB SSD Pro Tools 2024.3 EuCon 4.8.6.41 / 2023.11 UA Luna UAD 11 UA Apollo Twin X Avid S1 / Fire10 - 21.8.1.0 PreSonus DigiMax FS 8-input ADAT Dynaudio Monitors PreSonus Temblor 10 Sub Check my Music out here: Paul G YouTube Paul G Bandcamp |
Re: Plugins on a mixdown track
Yes, however a couple things to remember, in order to bounce to disk Aux inputs tracks coming in live (in real time)
low latency must be off. You can fix your midi timing problems by setting your playback buffer to 128 or lower providing your computer can keep up. The lower the better. 32 samples if you run PT 7.4. (You may want to pre-record your midi tracks in to a stereo audio track before mixdown if you have a slower computer or a lot of plugs/instruments running. Deactivate all other tracks then record midi stuff in) Don't forget to put a dither plug on your master fader (last in the chain) if you are changing bit depth/sample rate. |
Can't assign audio to new track for mixdown | LSJ | Pro Tools TDM Systems (Mac) | 1 | 02-09-2011 06:29 PM |
Disappearing Track in Mixdown | raiderrob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-07-2010 03:00 PM |
Plugins on Master Fader or Main Mixdown Track | studioslave77 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 12-20-2007 12:02 PM |
Mixdown recording to track | tonzauber | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-03-2006 03:05 AM |
Plugins used during mixdown demo at NAMM | rmandelbaum | Tips & Tricks | 0 | 03-03-2006 07:09 PM |
