Old 06-07-2019, 02:12 PM
Markrosoft Markrosoft is offline
Default Plugin Window Disappears if I select another Track
Either updating to 2019.5 or deleting my preferences is causing something I've never experienced: if I open a plugin window and then just select a different track (NOT another plug-in, but literally just select another TRACK) the plugin window I opened disappears.
So, just to make this clear... I open Kontakt on a track called Piano. Then I just click on a track called cello and my Kontakt piano disappears.
This never used to happen and for the life of me can't find where the setting is to change this back to the normal behavior - a plugin window stays open until you close it or open another plugin. I know I can click the red box to leave the plugin open but again, I'm looking to return it to the default behavior.
Does anyone know where this preference can be changed?? Thank you for your help!!
Old 06-07-2019, 02:47 PM
BScout BScout is offline
Default Re: Plugin Window Disappears if I select another Track
It has to do with Eucon. Do you use a Eucon controller (is it turned on in Peripherals)? There are a lot of options now on how plugin windows (and pan and send and etc.) operate when a track is brought to attention.
You just need to go through them to find what works for you in Eucontrol.
Old 06-09-2019, 08:12 AM
Thank you - you are totally right. For anyone else coming across this problem, you just go into EuControl Settings -> General -> and then unclick "Close Windows on Workstation When Exiting."
Thanks again BScout.
Old 07-25-2019, 12:32 PM
glennaudio glennaudio is offline
thanks for this solution. this was driving me crazy!!!
Pro Tools Carbon | HD Native 2021.12 | HD I/O 8x8x8 | UA 4-710D | Avalon VT737 | Waves Mercury | Komplete 13 Ultimate Collector's | Kontrol S61 | Maschine Studio | Eleven Rack | Pro Tools Control w/ 9.7" iPad Pro | Pro Tools Dock | S1 | MacPro 7,1: 16-core 96GB RAM W5700X GPU OS 11 1TB SSD +OWC 1m2 2TB SSD (samples) +Sonnet M.2 4x4 4x2TB Samsung Evo Plus SSDs in RAID 0 (sessions)
Old 07-25-2019, 09:30 PM
DAWgEAR's Avatar
DAWgEAR DAWgEAR is offline
Thanks from me too!
Pro Tools HD Native 2023.12 | HD Omni | iMac Pro 10-Core 3.0 GHZ - 64 GB - 2 TB - Vega 56 | Ventura 13.5 | Sonnet Echo Express SE II for PT HD Native PCIe and UAD 2 Quad PCIe card | Avid Dock and S1
Old 07-26-2019, 12:42 PM
Eric Lambert's Avatar
And there are many of us who are seeing this behavior randomly. There was a thread about it when 2019.5 was first released. A Eucon update around that time did help but unfortunately it's back again.
Old 07-31-2019, 11:02 AM
magnumpraw magnumpraw is offline
Holy smokes, thank you!! This has been driving me insane!
Old 10-15-2019, 10:48 AM
Dizzi45Z Dizzi45Z is offline
Yeah, this has been driving me crazy for 5 months! I checked EuControl Settings a bunch of times and didn't see the setting. That preference should be renamed from "Close Windows on Workstation when Exiting." To "Close plug-in Windows when selecting another track".
I'm so glad someone figured out what setting that was.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 12-09-2019, 02:38 PM
jasperbhome jasperbhome is offline
This just started happening for me with Eucon 19.12.0.71. Thanks for figuring this out!
Old 01-06-2020, 03:36 PM
heykenny heykenny is offline
Thank you!! This was driving me crazy. Just started happening and I looked everywhere in Pro Tools with no luck. Never considered it might be in EuCon.
Keyboard shortcut to arm/select next midi track in mix window ronwasserman Pro Tools 12 2 01-25-2018 01:32 PM
Plugin window follow select? jasenj1 ICON & C|24 2 10-08-2014 07:39 AM
No "Select Next Track" key command for mix window? Benny_Cha_Cha Pro Tools 11 3 08-17-2014 07:38 AM
Is there a way to automatically bring a track you select into view in the edit window Focuret Artist Series 4 01-05-2013 01:48 PM
clicking Apple + Auto on a track plugin window Pete Gates Pro Tools TDM Systems (Mac) 1 11-09-2005 10:47 AM
