Old 09-12-2019, 08:38 PM
ubergenius48@gmail.com ubergenius48@gmail.com is offline
Default Pro Tools First error when creating project
First time trying to use this program. I am using Pro Tools First 2019.6 with Windows 10. When I hit create, I get this error and I have no idea how to fix it:
Could not save as "0000" because Assertion in "E:\ Code\ 238949\ ProTools\ NewFileLibs\ Sys\ Win32\ Sys_VolumeWin32.cpp", line 352.
(Use the Copy button to copy this message to the clipboard.).
Any suggestions for how to fix this are greatly appreciated.
Old 09-12-2019, 09:39 PM
Default Re: Pro Tools First error when creating project
Hi, welcome to DUC.
First: please try searching for past threads before posting. You can almost always solve Pro Tools ASSERT error by careful searching for past posts here or in the Internet. The line numbers in the error message may change but the causes are usually the same.
See if this helps, are your running accounts off a network?
http://duc.avid.com/showthread.php?t=383903
If you still have a problem...
Post a Sandra report for your system. See under "Help Us Help You" up the top of each DUC web page.
What playback engine are you trying to use?
Old 09-14-2019, 12:21 PM
Thanks for the reply. I am using a Microsoft account on my home computer. It turns out that was the problem. I created a local account and now I am no longer seeing the error. Thank you so much! <3
Old 09-14-2019, 01:59 PM
Southsidemusic's Avatar
Darryl is awesome and Thank you too for letting others know what solved your assertion error
Best Regards
Christopher
South Side Music Group
WEBHOME
Project error (Pro Tools First) Math0588 Windows 1 12-23-2017 10:18 AM
permission denied while creating project cache midnightfluff Pro Tools | First Discussion 1 10-09-2017 11:39 AM
Could not create a new document because Permission denied (13) while creating Project AlasdairMacdonald Pro Tools | First Discussion 1 06-19-2017 04:20 AM
Error when creating project from template maartenl945 Pro Tools | First Discussion 2 09-28-2015 01:00 PM
Creating Project Templates in PT 7.3 spartikus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-24-2006 10:58 AM
