Old 07-18-2019, 04:47 PM
guitarist9891 guitarist9891 is offline
Default Avid S1...I am excited!
As someone who loves and uses his artist mix daily with pro tools I am really excited about the new S1. Would LOVE to see them side by side. (Artist mix and s1) Also is there actually any new functionality or just updated hardware?
Last question - I hope the iPad holder can be removed as I plan to use the device on its own most of the time. Nothing against pt control it’s just I find I only use the app when I track vocals as it allows me to remotely control PT when I am by my mic.
Will definitely pick 2 of them up. Almost bought a second artist mix on eBay like 5 days ago...phew��
Old 07-18-2019, 05:18 PM
BScout BScout is offline
Default Re: Avid S1...I am excited!
In the barebone pictures (no iPad) it does not look removal. It looks like one piece as part of the overall case. Of course it is much lower profile without the iPad in place.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 07-19-2019, 07:49 AM
http://duc.avid.com/showpost.php?p=2533168&postcount=24
PTHDn 2019.6 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 07-19-2019, 10:15 AM
Thanks for the link. I can live without automation select on S1. I rarely switch automation modes on the artist mix, usually do that with my trackball. The fact that the iPad holder is permanent is unfortunate. Still if it has better faders and rotary encoders it is an improvement.
Maybe I can find a couple of really cheap android tablets and just use those as a permanent meter bridge.
Old 07-19-2019, 11:17 AM
Originally Posted by Frank Kruse View Post
Guy is wrong on automation.
You hit shift and then click on the Rec button next to the fader (which is why there's a little "A" button in inverted white on the Rec button -- same as the Dock fader which has that option to also change automation modes)
Old 07-19-2019, 11:25 AM
EddieJones's Avatar
EddieJones EddieJones is online now
The Tablet holder isn't that high and was designed to go under an normal monitor. You can even then pull the monitor down over it.
It has new automation red and green LED's next to the Faders and Knobs which greatly helps see whats writing. New Track Color LED's which are also softkeys. Strong magnets in the sides that hold multiple S1's together. We moved the Sel and Rec up out of the way of the fader too.
The new Control App is completely rewritten from the ground up adding many UI customizations, Portrait mode, EQ/DYN graphs, Android and iOS, Phone and Tablet and when tied with an S1 provides the same high resolution meters S6 has including gain reduction. Its will still be free.
Old 07-19-2019, 12:46 PM
ubxf ubxf is offline
will the new control app add the metering feature to the S3 as well as the S1
Old 07-19-2019, 12:53 PM
EddieJones's Avatar
We are not sure yet, early days. Top priority is to get it working smoothly for the S1 launch.
Old 07-19-2019, 02:25 PM
cool it makes sense, at some point if it's not against company policy i'd love to tryout the beta of the control app
Old 07-19-2019, 04:57 PM
mattrixx mattrixx is offline
I am wondering how the high res metering is tied to the S1 ?? I'd have thought that the app would be agnostic to the surface being used in that sense? ??
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
I am really excited about EC 3.4! hanksinclair Artist Series 3 06-30-2016 02:53 PM
I'm So Excited! vocalize 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-16-2005 08:10 AM
Something to get excited about The Lone Roger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-15-2003 07:54 AM
I'm so excited!!!.... bassmac General Discussion 11 10-31-2002 11:08 AM
