Old 07-17-2019, 01:49 AM
Disound Disound is offline
Default The problem with automation
Hello, guys!
When I drag and drop any file from the cliplist to the session's timeline, to the place where some automation already exists, like volume or pan etc, that automation does not reset automatically. How to make it possible to drag and drop new clips without saving the old automation?
Old 07-17-2019, 06:31 AM
reichman's Avatar
reichman reichman is offline
Default Re: The problem with automation
That's a feature! Not a problem.
But if you have PT Control on an iPad, under Auto Edit there's a command for "Clear All Auto."
Or, you could use opt-cmd-slash to Write to All Enabled to freeze the automation over that clip.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Old 07-17-2019, 11:36 AM
BScout BScout is offline
I think if you turn on automation follows edit (forgot exact name), the automation will zero out with new clips. Can’t test it right now as I’m away from my rig.
Got back to system, tried it, doesn't work. Never mind.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Last edited by BScout; 07-17-2019 at 04:46 PM. Reason: update that suggestion doesn't work
Old 07-18-2019, 07:36 AM
Thanks for the answer!
In my opinion sometimes this feature is uncomfortable. For example I often have to add different sound effects to the session's timeline during sound editing for movies. And when all tracks are displayed as waveforms, automation's curves are not visible. Therefore each time I have to check it again and again.
I encounter this problem not only with working with the cliplist, but also with workspace, soundly, etc.
Thank you for your advice! I'll try PT Control on an iPad.
Old 07-18-2019, 07:37 AM
It would be a good feature. Imho
Old 07-18-2019, 07:45 AM
reichman's Avatar
If you're in post, you will want all of your tracks to be at some neutral setting for the entire session, and you should only be automating the section or scene that you're working on, leaving everything before and after at the neutral setting. Preview and Write to Selection are especially useful functions for working in this manner. If you start this kind of workflow, you won't have this problem. Make sense?
Nathaniel Reichman
Dubway Studios
Old 07-18-2019, 08:36 AM
What Reichman said.
In addition, you can click the automation lane button on tracks to create a second lane (or third, etc) that keeps other automation always visible while the waveform view is always visible on the main lane.)
Old 07-19-2019, 05:18 AM
Thanks for the recommendations, guys!
Problem with Automation bobrdld Tips & Tricks 10 02-11-2014 09:48 PM
Anyone Had This Automation Problem? tomhartman Pro Tools TDM Systems (Mac) 1 04-06-2007 07:54 AM
PT7 automation problem Paul Maunder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-16-2006 05:38 AM
Problem with the PT automation worldsend Tips & Tricks 11 10-07-2005 08:09 AM
Automation problem Jeff Zubeck Pro Tools TDM Systems (Mac) 2 01-02-2002 04:43 PM
