Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
  #221
Old 08-21-2019, 08:56 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: NVMe upgrade for Mac Pro 4.1/5.1 Mojave
Google for "cpusetter"
Janne
  #222
Old 08-21-2019, 09:12 PM
Guys be very careful of going around in circles.
Disabling hyper-threading on a Mac was an important tool to use at times, but mostly before Pro Tools 2019.x with its much improved threading support. And the need to do this varied greatly with plugin usage and depth of plugin and bus chaining.
So let’s start by being clear what version of Pro Tools you are all talking about.
  #223
Old 08-21-2019, 09:46 PM
WorldStudios WorldStudios is offline
I am on the latest version of everything and I get clearly less errors by disabling hyper threading. I know it’s supposed to work better now, and perhaps it does for some but on my system, HT stays off.
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
  #224
Old 08-21-2019, 09:57 PM
And the next question is what plugins... this is likely very plugin dependent... but the good point here from this is *try* disabling hyperthreading if you are seeing CPU errors. (And please share as many details as possible if it helps you).
For myself, 2019.5 ended my playing with disabling hyperthreading, I use very few non Avid (complete plugin bundle) plugins, mostly extra stuff is from Positive Grid and Toontrack drum VIs.
  #225
Old 08-22-2019, 03:35 PM
ghostwriter's Avatar
ghostwriter ghostwriter is offline
I too am running the latest versions of everything on a Mac Pro Mid 2012 12 core. I just randomly grabbed DSP plugins and through them on. So, my test was not real world or scientific. My screenshot could better explain which plugins than I could. I like being able to turn hyperthreading on and off with cpusetter so easily, to see which is better for the situation I’m in.
A few of of my favorite toys: Retro Instruments 176 (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM 70, SPX90, Roland SDE 3000...
  #226
Old 08-23-2019, 02:25 AM
arche3's Avatar
arche3 arche3 is offline
Gonna try cpu setter today. Thanks.
Sent from my SM-G975U using Tapatalk
  #227
Old 08-23-2019, 02:59 PM
arche3's Avatar
"CPU setter" hyper threading off didnt help. Actually made it less stable. Latest pt with hdx. 12 core cheese grater. Better for me normal setting.
  #228
Old 08-26-2019, 12:40 AM
Good morning! I would like to share my findings regarding putting an older AHCI blade in the Crest card. It makes the drive faster. The write speed almost doubled. Probably because the old adapter card was not as fast and/or seated in a 4x Pci slot. The top one. The crest card is in the lowest available 16x slot. So, the pictures show the same drive, a SAMSUNG MZHPV512HDGL in a regular simple PCI host card (lower values) and then in the Crest card slot 2. Slot one on the Crest card holds a Samsung SSD 970 PRO 1TB and that is much faster. The 970 Pro gets to 2600 write and 2800 read on a good day.
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
  #229
Old 08-26-2019, 12:26 PM
Thanks for sharing your results.
The difference in speed you are seeing is the actual magic of this adapter card. The PCIe switch on the card is doing PCIe 2 to PCIe 3 link aggregation, turning pairs of slower PCIe 2 lanes in the Mac Pro into a PCIe 3 lane, and doing that across 8 down to 4 lanes. This sort of lane aggregation happens down at the PCIe hardware level so is possible to just work with different devices, with maybe some exceptions, but in this case does not care about AHCI vs NVMe... they are higher level disk protocols running over PCIe. Most M.2 PCIe slot adapter cards have no switch at all, they are dumb a rock and just directly wire the slot lanes to the M.2 connectors. Which is why they can cost ~$20 each.
And to make it clear to folks the older model number AHCI drive being discussed is the Samsung SM951.
With PCIe 4 SSDs starting to appear, we will likely end up doing similar in future with the PCIe 3 slots in the new Mac Pro cheese graters..
  #230
Old 08-29-2019, 12:30 PM
K Roche's Avatar
K Roche K Roche is offline
I am happy to report my upgrade is now complete (including Mojave 10.14.6)and PTHD 2019.6
And all is going great. The Mojave install with my no boot screen Graphics card was more straightforward than I had anticipated
Also my power on, to desktop is now about 40 seconds
I have not done any recording but have loded played and done some mixing on about 10 previous sessions without any hitch (Very stable)
System :
Avid HD Omni I/O Interface ...Mid 2010 Mac Pro/ processor- 3.33 6-core Intel Xeon "Westmere" w/ Memory- 24 GB, Radeon Pulse RX 580 8GB GDDR5 Dual HDMI Graphics Card..... OS- Mojave 10.14.6, and PTHDN 2019.6 on on primary boot drive (SSD PCIe 512 GB Samsung SM951) FCPX files storage on Samsung 970 EVO 1TB and PT sessions storage on 2nd Samsung 970 EVO 1 TB -- both in dual drive Crest I/O PCIE controller adaptor card
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
Mac Pro 2012 -should upgrade to Mojave? Zak7 macOS 5 06-04-2019 07:51 AM
Mojave? hanksinclair Artist Series 3 05-03-2019 03:19 PM
New 8th Gen i7 with NVMe m.2 SSD spock999 Pro Tools 2018 26 02-22-2018 11:47 PM
Bootable Thunderbolt case for NVMe drives (Samsung 950 etc) propower General Discussion 1 10-27-2016 04:11 PM
Intel SSD NVME/PCIe Porn Darryl Ramm General Discussion 0 04-03-2015 02:02 PM
