Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 04-18-2018, 05:23 PM
DamienP DamienP is offline
Default Does send level impact the quality of process?
I've made this test in Pro Tools 10 :
Channel 1 : Dialog -> send 0dB -> Reverb -> Fader 0dB
Channel 2 : Dialog -> send -60dB -> Reverb -> (Trim +12dB) x5 (+60dB) -> Fader 0dB
Then I reverted the phase on Channel 2 and I summed Channel 1 with Channel 2. The two signals nulled, they are the same.
Same result with another reverb.
Conclusion : no matters the level of the send, the reverb gives the same signal.
Anybody can explain that? I assumed that sending to the reverb a signal with 60 dB reduction would drastically change the result of the process.
Thank you.
Old 04-18-2018, 06:20 PM
BScout BScout is offline
Default Re: Does send level impact the quality of process?
32 bit float processing.
Unless the reverb you used is affected by incoming signal level, sending lower or greater and returning to the same level will result in the same return signal. You are looking at +1000dB headroom and no added noise floor (unlike an analog mixer when sending less changes the SNR when you bring down the signal)
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 04-18-2018, 06:26 PM
Thank you very much for you answer. I realize I've always been lazy about that 32 bit float thing and the useful implications I can get from it. Now I get it.
copy a send (w/send level intact) from 1 to 30 audio tracks? MixerGuy Pro Tools TDM Systems (Mac) 3 12-30-2007 03:20 PM
7.3.1 Send level meter just mirrors track level bashville Pro Tools TDM Systems (Mac) 11 01-16-2007 08:19 PM
value of send level lost in pt7 cs2 m4tune Pro Tools TDM Systems (Mac) 0 02-20-2006 07:30 AM
6.9 Automation Send Level Bug Desert Fish Pro Tools TDM Systems (Mac) 0 05-28-2005 11:12 AM
channel level mirrored in send level meter daveh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-01-2001 01:32 AM
