Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 04-08-2018, 05:41 AM
marchseventh marchseventh is offline
Default Peaks and System sound volume slider
Hi Friends,
I recently mixed some sound effects for a game like products. They will use them in windows 8 system.
Then the feedback is all sound effects are too loud when the system volume slider has set 100%. If they adjust the slider to 65% sounds good. But they must to set that slider to 100% for other reasons.
So I have to reduce the volume by pro tools before bouncing to files. To get to know the relationship of the meter of system slider and peaks in pro tools. I have collected some data. But know I have no idea how much do I reduce all the sound effect. Is any body can help me to calculate ?
I attach the sample data here:
slider peak RMS LU
100 -0.7 -9.6 -5.5
95 -1.6 -10.8 -6.5
90 -2.5 -11.5 -7.3
85 -3.3 -12.5 -8.2
80 -4.3 -13.4 -9.1
75 -5.3 -14.3 -10.1
70 -6.3 -15.4 -11.1
65 -7.4 -16.6 -12.3
60 -8.7 -17.6 -13.5
55 -9.8 -19.0 -14.8
50 -11.6 -20.6 -16.2
45 -12.9 -21.9 -17.8
40 -14.9 -23.9 -19.6
35 -16.9 -25.8 -21.7
30 -19.0 -28.1 -24
25 -22.0 -31.1 -26.8
20 -25.3 -34.5 -30.2
15 -29.8 -38.8 -34.6
10 -35.9 -44.0 -40.7
5 -46.3 -55.0 -51.2
0
Mac Pro 3.5 GHz 6-Core Intel Xeon E5, Mac OSS 10.12.6, Pro Tools 12, 16 GB RAM installed, USB Keyboard KORG KROME, UA apollo 8
http://www.KimangoStudio.com
Old 04-08-2018, 12:20 PM
BScout BScout is offline
Default Re: Peaks and System sound volume slider
Just do -6 dB (which is technically 1/2 amplitude)
-3dB is 1/2 power
-6.02 dB is 1/2 amplitude (voltage)
-10dB is 1/2 perceived loudness
And don't re-bounce. If your files didn't clip in the first place, just use clip gain to drop them all -6dB (you can highlight them all and use ctrl+shift+ up/down arrows; these are the mac shortcuts) to reduce the clip level. Then consolidate all the files and it will permanently apply the change to the file. Far faster (though you will need to rename the files)
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 04-08-2018, 12:31 PM
Originally Posted by marchseventh View Post
slider peak RMS LU
100 -0.7 -9.6 -5.5
95 -1.6 -10.8 -6.5
90 -2.5 -11.5 -7.3
85 -3.3 -12.5 -8.2
80 -4.3 -13.4 -9.1
75 -5.3 -14.3 -10.1
70 -6.3 -15.4 -11.1
65 -7.4 -16.6 -12.3
60 -8.7 -17.6 -13.5
55 -9.8 -19.0 -14.8
30 -19.0 -28.1 -24
5 -46.3 -55.0 -51.2
0
Also, what did you measure this data with? You would need to use pink noise and then use the RMS numbers (not peak since peak can be a function of crest values.) However, since SFX are not pink noise, it's all just an approximation anyway. The biggest issue is pink noise over what bandwidth since depending on the playback system, it can be extremely skewed. But since everything is an approximation anyway, you can use this method and just subtract for what you read as 65%. So according to your chart, that would be a -7dB drop.
Old 04-08-2018, 07:41 PM
-3dB is 1/2 power
Thank you friend.
Do I subtract 7.0db by peak or 16.6 db by RMS? The -7.0 was peak read as 65%. The -16.6 was RMS read as 65%
Here is a example, I have a sound effect original is peak: -12.0 and RMS :-16.9. How do I set the data in the Gain. RMS -7.0db or RMS -16.6 db?
PS: I test the numbers by a pinknoise
Old 04-08-2018, 08:54 PM
Sorry, this isn't making any sense. The difference is the readout at 100% vs 65%. And only RMS matters.
-9.6dBFs - (-16.6dBFs) = 7
so a reduction of 7
If the data sheet you compiled is from pink noise, then the only difference that matters is RMS.
When you "apply" it as a reduction to your own sounds it doesn't matter peak or RMS. -7 dB is -7 dB. If your feedback was it is too hot but sounds good at 65%, you do a global reduction. Everything goes down by the same amount. You don't calculate per clip. That's why using clip gain is an easy solution -- highlight everything and reduce the clip gain by -7 dB for every clip at once using the shortcut keys I stated before.
Then consolidate to make the reduced level part of a new file.
Old 04-09-2018, 01:52 AM
so a reduction of 7
Aha, yes, beats me, I didn't realized that there is the same difference 7db
Thank you very much. I'm going to reduce them.
Track slider volume, HOW to set precise value?? Surely its PT 101. i missed that... skronger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 07-04-2014 04:23 PM
instrument track volume peaks when instrument volume knob is down deadvisions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-12-2011 01:43 PM
Volume slider in Edit window Nazyr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-06-2009 08:11 AM
Can you do this in PT LE?: editing wave volume peaks. DJ Hellfire Tips & Tricks 5 09-06-2008 08:33 PM
Can I automate midi instrument midi volume slider? ChaplainPC MIDI 6 07-08-2006 06:33 PM
