Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 03-11-2018, 05:11 PM
andydadd andydadd is offline
Default D Command Talk Back into ProTools
Hello everyone.
Is there a slick way to get the Talkback Mic on the D Command (Xmon) into Protools. The intent is to use it with Source Connect as a talk back with remote talent. Or, if you have a better way to achieve this, would love to hear your ideas.
We are running a Mac Pro 5,1 with Avid MTRX and Rednet 32R's.
Thanks!......Andy D.
Old 03-11-2018, 06:35 PM
Default Re: D Command Talk Back into ProTools
Don't have a D Command, but the C24 has a TB mic output on the back so take a good look(or check the manual). If you find a TB output, just route it into your interface and assign to an AUX track
Old 03-11-2018, 07:28 PM
Top Jimmy's Avatar
The TB/LB/Util port on the Xmon has an output for the talkback mic. Patch it to your interface and you'll get the talkback mic in Pro Tools.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 03-11-2018, 09:49 PM
Thank you for the quick write backs.
I should definitely have given some more explanation. In order to make my setup smaller, I decommissioned the 192's and went with the Avid MTRX which doesn't have any analog input (at this point, unless I buy an additional card).
Audinate is about to release an analog to Dante converter (adaptor I guess is what you would call it), but it's not available quite yet. I was curious if there was any other way to get the talkback mic into protools I'm not considering. (other than going out of the Xmon back into an analog converter).
In advance, thanks so much!
......Andy D.
Talk back or Talk thru - I don't know.... March314 FireWire and USB Audio Interfaces (Win) 1 09-05-2013 07:04 PM
Talk back jackp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-19-2006 06:53 PM
talk back srsoundlab 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-26-2005 02:51 PM
talk back Loftman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-05-2002 09:18 PM
Talk Back N-G-NEER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 06-29-2002 03:43 PM
