Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 11-14-2017, 04:29 PM
Timberwolf Timberwolf is offline
Default Pro Tools SE Microphone
Can you use a non M-Audio microphone with SE and if so how. I can't get it to recognize one !
And can it recognize two microphones ?
Old 11-14-2017, 05:21 PM
Top Jimmy's Avatar
Default Re: Pro Tools SE Microphone
The best I can remember is that SE only worked with the interfaces that came with Avid's Keystudio, Recording Studio, or Vocal Studio bundles. The Recording Studio bundle came with the Fastrack interface with one mic input. You can try the Fastrack duo for two mic ins, but I wouldn't be confident that it would work.
No, you can't use two USB mics at the same time with SE.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 11-14-2017, 05:22 PM
Pro Tools SE is restricted/licensed to certain interface devices, it will not work with other devices.
And its old and crippled software. Pro Tools First is at least new and crippled software, but you can use it with any interface. Pro Tools First is "Free" but has other serious limitations starring with it is not compatible with sessions from other versions of Pro Tools and can't use plugins not purchased from the Avid online store. Make sure your computer meets all systems requirements if you are using Pro Tools First. There are also many good low cost DAWs out there, Reaper, Studio One, etc. My personal bias would be to get a full copy or Pro Tools.
You also need an interface to connect a Microphone to, avoid buying more USB type microphones they are usually a waste of time, especially if you want to record multiple sources at once.
If you describe what you want do, what you are recording for what etc. how many simultaneous inputs etc. and an idea of your budget people here can make recommendations for interfaced and microphones.
Old 11-14-2017, 05:50 PM
Thank you for your input. That's not what I wanted to hear, but was afraid was the case ! SE has worked great for me up to this point but I need to do more and really can't afford the full blown version right now. I am recording songs for a music CD with each vocal and instrument on different tracks. It would help if I could record two different tracks from two different mics at the same time. Unfortunately I already have 4 of the songs done with SE and four others started so it would be a bummer to have to change software now if the SE files don't work in the new software. I'm up for considering any and all suggestions.
Thanks Again !
How Do I get my Microphone to Communicate with my Pro Tools 9. East25 Pro Tools 9 3 11-21-2014 11:07 PM
Pro Tools SE Microphone set up UnionPacific7004 Pro Tools SE and Essential (Mac) 2 07-21-2013 12:02 PM
Pro Tools M-Audio Microphone Sensitivity ilp123 Pro Tools SE and Essential (Win) 1 08-13-2012 11:04 AM
HELP: Pro Tools LE 8 & sE Z3300a Microphone glenn1019 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-04-2012 02:02 PM
pro tools and microphone record thing protoolsfanatic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-04-2009 12:15 AM
