Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 10-26-2017, 09:15 AM
teddydbme teddydbme is offline
Default Convert a Session Created in Pro Tools SE to Pro Tools First
I have been using Pro Tools SE, which came with my Avid Fast Track C600, for about five years. Recently, I decided to download Pro Tools First and give it a try, with the idea that if I liked it, I would ultimately upgrade to Pro Tools 12. I wanted to take a project I started in Pro Tools SE and move it to Pro Tools First to continue editing it. I clicked on the "Convert Session" button in Pro Tools First and pointed it to the .ptf file, but I got the following error: "Could not complete your request because magic ID does not match."
How can I access a Pro Tools SE session in Pro Tools First and continue to work on it there?
Thank you!
Old 01-03-2018, 02:48 PM
Default Re: Convert a Session Created in Pro Tools SE to Pro Tools First
Do you still have SE available? If yes, I would open in SE, consolidate all the audio back to zero and export(then import the audio into a PT First session). If not, you could try creating a blank session in PTF and try to Import Session Data and bring all the tracks into a new session. wish I had more to suggest but I've been on the full version and am not clear on the limitations of SE or FIRST. They are both "teaser" programs designed to get you to buy the full version
Old 01-03-2018, 03:17 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Easiest if you still have access to SE. The manual for the full version of protools is available on the avid web site and has all the conversion info needed. PT first does not use Sessions it uses "Projects" so you will have to most likely create an empty Project and import .wav files of each track and rebuild it that way. If your old stuff was not saved as wav or aiff files then they may have to be opened in LE then exported as wav's. I don't remember for sure but I didn't think PT first had the conversion function available
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 32 Gig Memory:Seagate 2 TB,1TB,4TB,500gb EVO OS Windows 7 Ultimate
PT 2019.6 Native through A&H Qu-32
Can I open a session created with Pro Tools Express in PT11 | HD? ArKay99 Pro Tools 11 5 01-07-2015 07:37 AM
Pro Tools 10 won't open session file (Created on a newer version) sjafarzadeh Pro Tools 10 5 07-16-2014 12:03 PM
This session file was created by a newer version of Pro Tools [7.4.2f109] olivergodfrey Pro Tools M-Powered (Mac) 3 02-12-2013 04:53 AM
PC doesn't read Mac (created) Pro Tools session digieric Storage Subsystems 4 12-23-2009 12:26 PM
"session created with invalid configuration of Pro Tools" aconk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-26-2008 12:32 PM
