Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Dock
Old 02-13-2017, 06:58 PM
Mike Landolt Mike Landolt is offline
Default Dock fader sucks!
I've owned a Control 24 and just sold my D-Command ES. I just picked up the Dock...this fader feels really rough. It's stiff and mechanically really loud. Is this normal or is it just mine? I was planning to add an S3 as well. Is the S3 fader is the same as the Dock? Does anyone feel the same?
Old 02-14-2017, 06:12 AM
yoerik roevens yoerik roevens is offline
Default Re: Dock fader sucks!
S3 faders feel is fine imo, i.e. much smoother and more silent than D-command. Unfortunately, resolution is far less (not sure if that`s a hardware/software) thing:
above -10dB : 0.1dB
below -10dB :
- steps of .3 - .4 dB in protools
- steps of 1dB on S3 displays
(.1 dB on D-command, still .2 dB until -40 dB)
however, if you're planning on using your console intensively for automation, the S3 is a no-go as you can see in plenty of other threads in the S3 section.
Old 02-14-2017, 06:14 AM
might be of interest to you as well: knobs on S3 are a disaster: very jumpy, terrible ballistics and no fine control.
http://duc.avid.com/showthread.php?t=365004
Old 02-14-2017, 07:52 AM
Are you currently using an S3 and a Dock? Reading through the thread people mention a sensitively issue with panning...has this been fixed? One thing the eq "Q" like in Waves SSL and Avid eq's are not populating on the Dock controllers. But the Native Instrumentals solid eq does work.
Best
Old 02-14-2017, 08:49 AM
no, it has not been fixed and it does`t look it will be anything soon (see link above)
What Avid eq are you talking about? all stock stuff seems to populate fine afaik, but I might have missed one or two.
I haven`t seen plug-ins not populating (although some do not populate all parameters).
I also noticed quite some Wave plugins are not controllable from the s3. Although they populate right, the scaling of the knobs is completely off with various Waves plug-ins.
Old 02-15-2017, 07:18 AM
Anthony_Anz Anthony_Anz is offline
That's a whooooooole other issue... =)
http://duc.avid.com/showthread.php?t=381425
Old 02-15-2017, 08:20 AM
That one's terrible indeed, however that`s not what I meant.
I was talking about plug-ins where you just barely touch a knob and the parameter jumps all the way to the other end. As if the scaling is about 100 times too sensitive.
Old 02-15-2017, 11:26 AM
Yeah, I know what you mean about the sensitivity of the controllers...after spending all day with the dock I do like the features plus the intuitive nature of the Control App and I'm getting used to the more robust fader. 3 1/2 years ago I owned 2 Mixes and a Control. The Eucon software was really inconsistent so I sold them and bought a D-Command ES. Now full circle Eucon is better just need to dive into the software. It is crazy though the Avid eq 7 band does not populate with "Q" point on the controllers...
Old 02-15-2017, 12:07 PM
I thought you could press the SEL button (on the PT Control App) next to any of the frequencies that have a "Q" in order to see the Q param...
Old 02-15-2017, 09:40 PM
Mark Ziebarth Mark Ziebarth is offline
The Q control is a little hidden. It took me a few days to find it. I guess it's in the second layer because it wouldn't match with the eight available controls per layer. Four bands can have frequency and gain control. If every band would over three parameters there would be two bands with full parameter set and two more controls available.
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac Pro 2008, RME Fireface, Pro Tools 12, Euphonix MC Control
Fader off on Dock?? KPereira Pro Tools | Dock 1 02-13-2017 12:22 PM
Suggestion: Users of S3&Dock together: dock fader becomes 5th VCA master fader bassmagnetic Pro Tools | Dock 0 10-01-2016 08:20 AM
WUP sucks!! c.evans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 26 12-23-2010 12:13 AM
Anyone else think PT7 sucks?? thegiantgeordie Pro Tools TDM Systems (Mac) 29 03-26-2006 08:19 AM
man this sucks keny 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-24-2003 06:14 PM
