Old 11-25-2014, 09:18 PM
prestonhavill prestonhavill is offline
Default help fixing plugin delay and delay compensation disaster
Help.
I am dealing with a very nice sounding album that was worked on by 4-5 different engineers who had little to no communication with each other. Certain parts were recorded with no plugins and delay compensation off. Certain parts were recorded with plugins and delay compensation on. Certain parts were recorded with plugins on and delay compensation off.
When i eliminate plugins and/or turn delay compensation on/off, certain parts just jump around and the whole thing is out of time. In some cases, there are sessions where a certain overdub track is sent to "Main Out 1-2", and the rest of the tracks are sent to an Aux called something like "MUSIC ALL". If I send those overdub tracks to the main Aux, they are significantly behind.
Additionally, some of the parts have been nudged by another engineer, to "fix" the problem, even though they would have been perfectly in time if plugins were removed and delay compensation had never been turned on. I have no way of knowing how to undo those nudges, as they were done by listening alone.
These problems occurred mainly because people started mixing while they were recording, and in some cases, musicians were recording overdubs with delay compensation on and significant latency.
I am pretty new to dealing with delay compensation in 10 and 11. Also, I will note, I understand exactly why this session got messed up, but not exactly sure the most efficient way to fix it. Right now I'm thinking about bouncing out stems one by one, as in, each track at a time, with 100+ tracks in some songs, on a 14 song album.
Any ideas? Thanks in advance for any help!!!
Old 11-26-2014, 08:15 AM
Default Re: help fixing plugin delay and delay compensation disaster
PS - I should mention that the person mixing these does not use PT and is expecting stems only
Old 11-27-2014, 02:23 PM
priorytools priorytools is offline
The nudged audio problem.
You could go into spot mode , use grabber tool, move regions. Select original timestamp in the window that pops up.
As an experiment, try making a new session then import session data from an original session. But ONLY the audio. No routing or aux channels. Then send all mults to the main out. See how sync is then.
~ Trashcan Mac Pro late 2013 - 64 GB RAM - 10.12.6 / Pro Tools HD 12.8.3 / HDX 2 + UAD2 PCIe OCTO in Magma Expressbox 3T / HD I/O's x 4 + 1 x 96io / Avid S6 M10-24-5 V3.6 ~
~ MBP 15" 2.8 Intel Core i7 -10.12.6 /Apollo 16 / Steinberg U22 / Artist MIx / Pro Tools HD 12.8.3 - UAD2 V8 / UAD2 Satellite DUO ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / HEAT / Magma PE6R4 / ProControl 24 faders / UAD2 QUAD PCIe ~ ARCHIVE RIG
Old 11-27-2014, 03:07 PM
Craig F Craig F is offline
Stems are sub-mixes of various parts
what you are talking about are whole files of equal duration not Stems
not that it helps with your timing problem but pleas use correct terms
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 11-30-2014, 01:50 PM
Thanks for the advice, I've been doing that in some cases
Old 11-30-2014, 01:53 PM
Thanks for the vocab lesson. However, I think everybody refers to "whole files of equal duration" as "Stems" when you are delivering them to somebody using a format other than ProTools. Even if they are "Kick", "Snare", "Hat", as opposed to "Drums", people would call that stems if it constitutes edited, rendered audio that is leaving a ProTools session.
Let me know if you have any advice for helping with the problem I mentioned above.
Old 12-01-2014, 01:05 AM
that just little music guys trying to sound like big film guys, nothing more and so much less (yes, I'm that jaded)
If I was told I was being sent stems and got consolidated files I would make the sender cry from verbal abuse.
the definition of a stem is: the whole of the mix is the sum of the stems with out any addition work/processing
Thank you,
Craig
Old 12-01-2014, 04:56 PM
Sweet, great, thanks again for the vocab lesson. Sounds like you are super smart, let me know if you plan on responding for the thread, if not, please find your own.
Old 12-01-2014, 04:59 PM
maybe i was wrong about the "stems" thing, although i was pretty sure it is the job of moderators to prevent trolling...
Old 12-01-2014, 11:13 PM
amazingrugs318 amazingrugs318 is offline
Super helpful moderator.
Mac Pro Cylinder 2013, Mavericks 10.9.4, 10 Core Intel Xeon E5 3.0 GHZ, 256GB Hard Drive, 32GB Ram
Pro Tools HD 11.2.1
HD Native PCIe and and UAD-2 Octo PCIe in Magma ExpressBox 3T
HD I/O 16x16 Analog
UAD Software 7.10
6GB Lacie 2Big Thunderbolt drive for Audio (set up in JBOD mode)
When do you NEED plugin delay compensation? JonnyGinese 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-17-2006 09:28 PM
Plugin Delay Compensation kurt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 34 12-20-2005 11:51 PM
Will PT7 LE have plugin delay compensation? Matiz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-17-2005 01:27 PM
plugin delay compensation? vieris Pro Tools M-Powered (Win) 1 06-19-2005 03:25 AM
plugin delay compensation liquid Digidesign Hardware & Software 0 08-13-2001 06:11 AM
