Old 04-13-2013, 08:06 AM
elmodagansta elmodagansta is offline
Default PT 9 - "Minimize additional I/O latency" PROBLEM
Dear PT users, I am using Scarlett 2i2 with PT9 on WIN 7 PROF (64bit). Everything is working perfectly apart from this small checkbox in Playback Engine "Minimize additional I/O latency". Each time I check it I get only clicks/pop heavy disturbed sound from my soundcard and no actual playback. I am recording at 48K sample rate with buffer lenght 4ms (this is what Focusrite panel's saying) and the input latency is 13,5, output 18,9. I was wondering if this feature "Minimize additional I/O latency" would help and if anyone can explain why I am experiencing this issue. Be glad for any clues. Regards.
Digirack 003 + ProTools12
Mac mini 2014; SSD 128; i5 2.6; 8GB; OS 10.13
Old 04-18-2013, 03:50 PM
Katherine_Focusrite's Avatar
Katherine_Focusrite Katherine_Focusrite is offline
Focusrite
Default Re: PT 9 - "Minimize additional I/O latency" PROBLEM
Hi elmodagansta,
I see you are having some problems with clicks and pops on your Focusrite 2i2.
We would be glad to assist you via our Contact Support page.
Generally I would recommend you set your ASIO Buffer in the Focusrite USB 2.0 Audio Control Panel to 1.0ms as this will allow Pro Tools all the options of different Buffer Sizes in it's Playback Engine. Now you can select an appropriate Buffer Size without needing that check box.
If you are still experiencing Latency or Clicks and Pops please feel free to contact us directly so we can assist you.
Best regards.
Katherine Kaplan // Focusrite Technical Support
http://www.focusrite.com/answerbase/en/
Old 04-27-2013, 06:11 AM
Terry Wetzel Terry Wetzel is offline
Excuse me, I also use Pro Tools 9,(.0,.6), and I've never noticed the "small check box, "Minimize additional In/Out latency". Is it in the preferences section ?
Minimize Additional Latency noise SearingSounds Pro Tools 11 14 06-12-2021 07:39 AM
i have a problem with "Pencil Tool". Why it's always in "square mode" ? ak11_lin macOS 6 08-25-2013 05:38 AM
Minimize Additional I/O latency william.bond55 Pro Tools 10 0 03-16-2012 08:44 AM
LE 8 install with Original Mbox: "Additional Files": Factory Bundle Installers amusos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-17-2011 07:53 PM
Rare Problem, Genius Required. "Reverse Latency" DSRecordings Pro Tools M-Powered (Win) 3 01-30-2010 06:03 PM
