Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 07-17-2010, 08:51 AM
Gunnell Gunnell is offline
Default Appropriate Access Privileges
I'm getting
Could not complete your request because you do not have appropriate access privileges (-5000) while creating "SESSION TITLE" while creating "Fade Files".
I copied a project to another hard drive, worked on it some more, saved it with a different session name, and then copied back over to the original drive. Now I get this error if I try to make any changes. It plays back fine, but I can't create fades or turn on elastic properties.
OSX 10.8
Pro Tools 10 / 11
Sapphire Pro 40
Mac Pro 2.66 GHz Quad-Core Intel Xeon
10 GB 1066 MHz DDR3
Old 07-17-2010, 06:00 PM
BBennett BBennett is offline
Default Re: Appropriate Access Privileges
Were you working from the same computer when you moved the session to an external drive? (I'm sure you moved it to work from another computer) Also, did you copy the entire session folder?
You can set permissions on files from individual computers to do different things. (Read Only, Write Only, etc.) As well, the full file folder contains a 'Fade Files' folder, but that shouldn't effect permissions, you should have just lost all fades that were applied.
When you changed the name, was it a 'Save As' or 'Save Copy In'? Or did you just change the name of the folder?
A little more information could help...
Old 05-13-2015, 08:01 PM
bigbassman bigbassman is offline
Default "You do not have authorization - 5000" message
I have the same issue. I have changed nothing since i overdubbed tracks last night.
Absolutely nothing.
This is VERY frustrating.
Can anyone offer some help?
Much appreciated.
Thanks
Old 05-13-2015, 08:30 PM
jeffro's Avatar
jeffro jeffro is offline
Question
Absolutely nothing.
Much appreciated.
Thanks
Search Knowledge Base (link above in header) for... you do not have appropriate access privileges 5000 ...returns a couple articles. Are either of those helpful?
...do not have appropriate access privileges ifix macOS 13 03-20-2017 12:30 PM
"Necessary access privileges"?? WTF???? Dopamine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 05-22-2012 06:25 AM
Access Privileges Chris King Pro Tools TDM Systems (Mac) 1 05-14-2005 07:42 PM
Access privileges colnago 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-28-2004 06:39 AM
"you do not have necessary access privileges " stickleback 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-10-2004 09:29 PM
