Old 01-29-2008, 11:38 AM
teacherman teacherman is offline
Default Pre-Fader Metering vs Post-Fader Metering
Is there an advantage to Cutting tracks and/or Mixing either in Pre-Fader metering vs Post-Fader metering?
MacBookPro 2.2 Ghz Intel Core i7; 16 Gig Ram; OSX 10.12.6; ProTools 10.3.9; Protools 2019.6
Old 01-29-2008, 02:36 PM
Shawn Simpson Shawn Simpson is offline
Default Re: Pre-Fader Metering vs Post-Fader Metering
I never use post-fader metering. When tracking, I want my meter to show me the input level. As long as the fader isn't moved from unity gain, it wouldn't make a difference, but that's not generally the case and certainly not worth counting on. I also don't use any plug-ins when I'm tracking either. When mixing, I stay in pre-fader metering so that if I mute mute a track it doesn't make the meter disappear and I can tell that there's actually some there.
I'd actually be hard pressed to tell you why you WOULD use post-fader metering.
Old 01-29-2008, 03:13 PM
asm's Avatar
asm asm is offline
I agree about tracking with meters set to pre-fader, but when mixing I want to know the level of the signal after plug-in processing and after gain is applied by the fader. This informs me of any clipping of the individual channels (actually I usually try to keep the channel level peaks to about -6b) and also indicates the results of compression/eq. Additionally, I can check for the balance between multiple channels and can tell which signals are contributing the most/least to the summing bus, whatever that may be. Pre-fader metering would not provide any of that information, unless I mix with faders at unity gain and no plug-ins.
During mixing I will occasionally check the pre-fader levels (usually until I am familiar with the mix) and during tracking I have had to switch to post-fader metering to confirm that "digital clipping" was occurring as a result of too much fader gain and not input levels. For example, pre-fader metering will not indicate an overload on an aux send feeding the artist cue mix that results from excessive gain.
Andrew Mittelman
www.soundgeneration.net
Old 01-29-2008, 07:33 PM
Tstein Tstein is offline
Ditto Shawn.
I only need one hand to count the number of times I've used Post Fader Metering in Pro Tools.
I very rarely use it on a mixing console when given the option.
If you are woried about clippng a PlugIn or summing stages there are meters and clip indicators, and even your ears to provide that information.
Ted
Pre Fader Metering Setting DonM Pro Tools 11 4 07-05-2013 08:28 AM
Pre and post fader metering on each track independently. Emcha_audio General Discussion 6 11-17-2012 12:34 PM
shortcut for pre/post-fader METERING switch. Stefan Luan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-04-2006 04:17 AM
Pre or Post fader Metering? Forrest77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-20-2003 12:35 AM
Pre-Fader metering? pk_hat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 06-16-2002 03:30 PM
