Old 06-18-2006, 06:50 PM
Howardk Howardk is offline
Default Delay Compensation - Delay Monitoring when REC
I was recording some tracks on a session that happened to have Delay compensation engaged. The session player (very experienced) said he was feeling a delay. I checked the path and there were very few plugins in the chain (nothing out of the oridinary from what I usually use). He was still convinced so I turned off Delay compensation and reopened the session. Delay gone. . . player happy. I would have thought delay compensation was not supposed to affect tracks in record. . . I will avoid it in the future, but thought it curious and worth a post.
HD 4 semi-Accel (Core, 2 x HD + 1 x Accel)
PT 7 cs6
OS X 10.4.3
See my Public Profile for System Configuration Information
(Click on member name)
Old 06-18-2006, 07:16 PM
25ghosts 25ghosts is offline
Default Re: Delay Compensation - Delay Monitoring when REC
normally ADC bypasses when u enter record - however if u hit ctrl+alt+apple and then click on the reported delay u can actually record with ADC on....Dont fry me on the key command or where to click but I know it is possible - u might wanna refere 2 your manual
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
Old 06-18-2006, 08:59 PM
Sound-Influence Sound-Influence is offline
It depends on how you are monitoring. ADC will kick off of the channel you are recording, but not the bus or send you are monitoring. Case in point - Let's say your record channel main output is direct to your audio interface. You have an output bus as a send on that channel - HP Mix1. If you monitor that mix (and the bus is not a send anywhere else) - no delay. If you have an aux channel submix (Main Sub) that you want to hear as well, and add HP Mix1 as a send on that channel, then the HP Mix1 bus inherits the ADC from the Main Sub and you will get a monitoring latency on the record channel.
There are some cases where recording with ADC on makes sense. For those cases you have to make sure that your monitoring path isn't picking up delay from anywhere else. Get in there and read the manual. Test some things. ADC does some weird things under the hood until you firgure out what's going on.
Good luck.
Aubrey
PT 7.4cs2 | OS 10.4.9 | Dual 2.0 G5 7g Ram | HD3 Accel | 4 FW800 Drives
Delay compensation with backline delay chuck goodwin VENUE Live Sound Systems 3 08-09-2013 07:54 AM
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing CNSound macOS 1 01-27-2012 11:10 AM
Delay compensation- choice of 'Medium delay'? dtmprod Pro Tools TDM Systems (Mac) 2 05-05-2010 11:00 PM
Delay Compensation....... BigEvil Pro Tools TDM Systems (Mac) 36 11-25-2008 11:41 PM
Delay Compensation Desert Fish Pro Tools TDM Systems (Mac) 0 10-16-2006 08:01 AM
