Old 08-18-2019, 10:48 PM
Geetar Geetar is offline
Default Is there a way to extract plugin settings from a project file?
I was just thinking about this while watching an Eric Valentine video - he had an older EMI compressor plugin in an old project which wasn't made anymore so he had to recreate his settings in a newer plugin. I know plugin settings are saved in a project file, but is there a way to "see" what the settings were for a specific plugin which might help you if you have to recreate a preset?
Old 08-19-2019, 04:11 AM
Default Re: Is there a way to extract plugin settings from a project file?
No.
Unless you can open the old plugin so you can manually copy down the settings.
Old 08-19-2019, 03:13 PM
I just found a GitHub project where someone is working on a way to reverse engineer the pro tools file format - I've emailed the developer to see if it will read plugin settings (since they're all saved in the project file somewhere/somehow)...
Old 08-19-2019, 08:06 PM
Mixchump Mixchump is offline
I know that SSL used to distribute a piece of Conversion software that would translate stuff to-and-from ProTools session files.
I'm pretty sure the session file format is encrypted, but if you save it as a PTS (ProTools 7-9), it might have better luck...
Help - PT 8 - How to extract Midi file MR290378 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-07-2011 07:20 AM
Can't Extract PT LE Zip File To Install- Help!!! numberforty1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-23-2010 04:21 AM
how to extract tempo from an audio file? musiquito Pro Tools TDM Systems (Mac) 36 03-04-2010 10:03 AM
How to extract audio from .mpg video file? X-man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-05-2002 12:58 AM
